Site broke down after the current update, both the frontend and backend returning error.
Hi see if Nginx and PHP are running?
systemctl status nginx
php-v check the version and substitute the value
systemctl status php8.2-fpm.service
Yes both running
Any update? my 3 servers are down. One running okay.
I just rolled back to version 8.12
how to do that? please guide
You can take a look here.
Error installing HestiaCP on Debian 12: Unable to locate packages & GPG key issue
Wat is your current Hestia version?
Tried to update to 1.9.2 but it fails too. this loop going on since last 1.9.0.
What was the version before 1.9.0?
I’m not sure, I only tried to update it through cli when I was unable to access the sites along with the control pannel and thought the update will fix, but that breaks.
