HestiaCP Auto Reply does not works in Oracle cloud
Hi!
I’m trying to use the Auto Reply function in Hestia. With a modified Exim4 template, I can send and receive emails, but I can’t get the Auto Reply to work.
When I send an email from [email protected] to [email protected], the auto-reply sends an auto-responding email to myself but not to addresses outside the server.
What am I doing wrong?
Thank you very much in advance.
Please check the exim log for information regarding the auto-reply messages.
 R=send_via_smtp_relay T=smtp_relay_smtp defer (-54): retry time not reached for any host for '[email protected]'
I asked Google before - but thank you for the friendly advise. So I see, that Im not alone with that problem at HestiaCP
https://forum.hestiacp.com/t/exim4-problem-with-aws-ses/13301
After a run the below to reset Exim db:
/usr/sbin/exim_tidydb -t 1d /var/spool/exim retry > /dev/null
/usr/sbin/exim_tidydb -t 1d /var/spool/exim reject > /dev/null
/usr/sbin/exim_tidydb -t 1d /var/spool/exim wait-remote_smtp > /dev/null
and then restart exim.
R=send_via_smtp_relay T=smtp_relay_smtp defer (-54): retry time not reached for any host for 'gmail.com
The first link that google shows you for this query, shows an example of using the exinext command to get more information about the error. Have you tried that?
Yes, I did:
exinext [email protected]
No retry data found for [email protected]
Some additional informations:
cat /var/log/exim4/mainlog
Without auto-reply:
2025-01-28 20:44:40 1tcrVo-000Fg6-9b <= [email protected] H=mout3.freenet.de [195.4.92.93] P=esmtps X=TLS1.3:ECDHE_SECP256R1__RSA_PSS_RSAE_SHA256__AES_128_GCM:128 CV=no K S=5310 DKIM=freenet.de [email protected]
2025-01-28 20:44:40 1tcrVo-000Fg6-9b => info <[email protected]> R=localuser T=local_delivery
2025-01-28 20:44:40 1tcrVo-000Fg6-9b Completed
With auto-reply:
2025-01-28 20:48:15 1tcrZH-000Fvm-8P <= [email protected] H=mout2.freenet.de [195.4.92.92] P=esmtps X=TLS1.3:ECDHE_SECP256R1__RSA_PSS_RSAE_SHA256__AES_128_GCM:128 CV=no K S=5321 DKIM=freenet.de [email protected]
2025-01-28 20:48:15 1tcrZH-000Fvm-8P => info <[email protected]> R=localuser T=local_delivery
2025-01-28 20:48:15 1tcrZH-000Fvv-LG <= <> R=1tcrZH-000Fvm-8P U=Debian-exim P=local S=614
2025-01-28 20:48:15 1tcrZH-000Fvm-8P => info <[email protected]> R=autoreplay T=userautoreply
2025-01-28 20:48:15 1tcrZH-000Fvm-8P Completed
2025-01-28 20:48:15 1tcrZH-000Fvv-LG H=smtp.email.eu-frankfurt-1.oci.oraclecloud.com [147.154.153.19] TLS error on connection (recv): The TLS connection was non-properly terminated.
2025-01-28 20:48:15 1tcrZH-000Fvv-LG H=smtp.email.eu-frankfurt-1.oci.oraclecloud.com [147.154.153.19] TLS error on connection (recv): The specified session has been invalidated for some reason.
2025-01-28 20:48:15 1tcrZH-000Fvv-LG ** [email protected] R=send_via_smtp_relay T=smtp_relay_smtp H=smtp.email.eu-frankfurt-1.oci.oraclecloud.com [147.154.153.19] X=TLS1.2:RSA__AES_256_CBC__SHA1:256 CV=yes: SMTP error from remote mail server after pipelined MAIL FROM:<>: 553 <> Invalid email address
2025-01-28 20:48:15 1tcrZH-000Fvv-LG Frozen (delivery error message)
Hi again.
Can nobody tell me whats wrong here? Is it only my “configuration” problem or an general exim4 bug?
From your log:
The autoreply message gets send with an empty enveloppe from address. This is not hestia to ‘blame’. It is the way exim works. From exim’s docs: To reduce the possibility of message cascades, messages created by the autoreply transport always have empty envelope sender addresses, like bounce messages.
But how do I then configure exim so that the autoresponder works?
