How can I solve this problem that appeared to me when I wanted to install the script, this problem appears to me
Hello. How are you my good friends? How can I solve this problem that appeared to me when I wanted to install the script, this problem appears to me. Please help me overcome this problem.
Even though I did PHP 8.2, the problem is still the same.
See the pictures to see what I mean.
If you have installed php 8.2 and then directly have proceeded with the above installation, then you may have missed one step of reboot.
Reboot your server and see, if the same mistake appears. This will also refresh or re-read the php environment.
I did a server restart as you told me. This is what happened.
If you need to activate the exec() function, then this is compromising on security features. Someone can execute malicious codes after activation.
However, if this is compulsopry to activate, then find this term in the php.ini and edit it, add it or uncomment it.
This install script checks certain prerequisites. If not found, it will give an error of 500. Nothing to be scared about. Simply fulfil the prerequisite and then you can proceed.
Please where do I search for exec() I don’t have much experience in this. Can you show me how to search for exec() and where do I find it?
Why do you ask questions on Hestia when you are using CPanel? I don’t understand! Has CPanel not replied to you?
