How to bypass "admin" replacement?
Really I would be okay with avoiding the replacement of “admin” credentials or just knowing how to create a new user with the same credentials as the original admin.
I am using an EC2 Debian 12 instance from AWS Academy, these machines require you to set a key for authorization.
Of course, when I run the Hestia installation, the credentials for “admin” get replaced with the new ones and AWS Academy only lets me authorize the remote connection via key, so creating a new user to authenticate as is just not possible.
Does anyone know if I can leave intact “admin” original authorization key?
In 1.9 we replace the user with an “user” generated account to solve this issue won’t solve it for now
That’s great. Looking forward to it.
Nevermind, turned out I was being ignorant, I just needed to change the settings in the file /etc/ssh/sshd.conf to allow password authentication instead and create a new user with sudo permissions.
I usually create users like 50 at a time
u101
u102
u103
u104
Then each user is owned by admin.
What exactly are you doing that you need another user with sudo permissions?
You’re on Ubuntu ?
Are you doing node.js or python or something??
Each user has one primary domain. Maybe a couple of other sub domains
I like having my usernames with the same length. If makes scripting easier
You see, my problem could just be solved by having password_authentication set for SSH, I was just having trouble to log in after installing Hestia, since I am using a VPS that has admin as their log-in user and a set of keys to authenticate.
I just needed another user having sudo so I could then log using root, because I also don’t have the password of root, given it is a VPS.
I just want the root privileges to examine the structure of Hestia, I am right now working on a project that makes a comparative between Hestia, myVesta and aaPanel.
Hope this solves the confusion, I really don’t need anymore help but maybe I did make it sound trickier or more stupid than it was, have a good day.
your vps provider INSISTS that ‘they are in control of the admin user’?
I’d find a new VPS provider. I’ve got plenty of affiliate links.
I don’t think that vps providers should screw with ANYTHING except the root user.
PS - one thing that is CLOSE to this same discussion, is I was writing some custom ‘uptime scripts’ yesterday… and I noticed that there is a GROUP called ‘adm’.
I assume that THE admin user is a member of ‘adm’ group.
I don’t know the ramifications of creating OTHERUSER1 and then assigning THEM to the adm group. IF I was designing the system, that’s all it would take.
