Once it finishes installing, I go back to the panel and I get an error 500
It does not allow me to enter the panel directly, I cannot see anything and what I do is a clean installation
If you canāt follow the instructions then donāt modify the code. 1.3.3 is the current release
Upgraded to CSF v14.09 and everything is working flawlessly.
Please follow the provided steps in the how-to tutorial as @eris pointed out.
When I finish the installation I get error 500 and in the error.log the following, I get repeated several times
2021/03/16 12:44:39 [error] 14813#0: *52 ā/usr/local/hestia/web/list/csf/index.phpā is not found (2: No such file or directory), client: 00.00.00.00, server: _, request: āGET /list/csf/ HTTP/1.1ā, host: "servidor.xxxxxx.com:80$
Iāve been looking and inside the folder ā¦
/ usr / local / hestia / web / list / csf /
we have a folder called images, and two files frame.php and index.php
any ideas?
And I apply all the steps to install them, the ones that are in the first post.
any ideas ???
This seems like a permission issue to me⦠Are you running on Debian?
Yes, Debian GNU/Linux 10 (buster)
to meā¦
Debian 10 hetzner cloud.
With a clean Installation the hestia panel works.
Then if install CSF I got error 500 in the hestia panel.
I tried many time with a clean installation but after the installing csf I got error 500ā¦in the panel !
Update : After I tried to uninstall csf and hestia panel works again.
Make sure you use
before to edit the panel html file.
I applied the steps in the first topic. Until dot 7 it is well, then when I apply the dot 8
8. sh install.hestia.sh
I got error 500 in the panelā¦
Check /var/log/hestia/nginx-error.log and check what Error is in it
no errorsā¦the file is empty
Today I tried to rebuild the vps with Debian 9. After installing the CSF
I got the same error: Internal Server Error 500 !
The nginx-error.log file is empty.
Update : Later I rebuild the vps with Ubuntu 18.04
Always same error : Internal Server error 500ā¦I donāt know think about it.
I have another vps (always with hetzner) with Debian 10 and CSF (the latest version 14.09 ) works well. It is On from 18 monthsā¦
@flanders Thanks for your input. Is the CSF panel working for you if you proceed with steps 1-6 & perform changes in the ā/usr/local/hestia/web/templates/admin/panel.htmlā file?
Also, please verify that ā/usr/local/hestia/web/list/csf/ā folderās content is not empty (from previous install).
