How to install and configure SQLite 3
Hi all,
I have installed SQLite3, php7.4-sqlite3, php8.2-sqlite3, php8.3-sqlite3, php8.4-sqlite3
I have enabled extension=sqlite3 and extension=pdo_sqlite
I’m having trouble getting my Laravel project to work.
I don´t want to use MariaDB. What I want is SQLITE.
Here is a post that has never been answered with the same problem
I appreciate any help you can provide.
Hi @fedekrum
I don’t use Laravel but what’s the exact error you get? Did you check the logs?
for i in $(ls -l /etc/php/ | awk '/^d/ {print $NF}'); do echo "Checking PHP $i"; php${i} -m | grep sqlite; done
dpkg -l | grep -E '^ii.*sqlite'
I forgot to say that you shouldn’t activate the extension manually, it’s done automatically when installing the packages. Maybe php is failing because it’s enabled twice.
grep -r '^extension=.*sqlite' /etc/php/
You are right !!!
I enabled all manually. I had disable them and it works.
Thanks !!
