Whats up,
I’m facing an issue when creating a new user in the system and installing a new Laravel app using the Quick Install option with “Create Database” enabled.
After installation, I encounter several problems:
- The
.envfile is set to useDB_CONNECTION=sqliteby default. - The database that was created during setup is ignored — its credentials are not added to the
.envfile. - When I try to access the site, I get errors like:
Database driver [sqlite] not supported.
or:
could not find driver
- Additionally, I get the following error related to Composer:
Error fetching Composer resource
It seems Laravel is trying to use SQLite by default (even though a MySQL database was created), and the system also fails to complete Composer setup properly.
Has anyone else encountered this? Is there a way to fix or avoid this issue during the Quick Install process?
Thanks in advance!
