IMAP 993 not working
Any idea how to setup email using IMAP with port 993.
Mine is only accepting port 143 however port 993 is allowed.
hi you need to be sure you’ve valid hostname and ssl installed for the hostname. How to install Lets Encrypt SSL in Hestia CP hostname, admin control panel and for Email Server - Other WEB Panels - Alpha GNU
and you need to use that particular hostname as ipmap hostname in your email client/script.
Also, Please confirm if port 993 is really open
SSL already applied and I can use email client but with port 143, 465 and 587
Yes it’s allowed
Send us some log or error message
How could I do that? From Microsoft Outlook
Appreciate if anyone can support on this
Show the output of these commands (as root):
netstat -ptan | grep -i listen | grep -i dovecot
v-list-firewall
