Issue with 1.2.0 RC
There are some issues faced by me while installing HestiaCP on Ubuntu 20.04
Details are …
OS - Ubuntu 20.04 (LTS)
HestiaCP Version - 1.2.0-rc-ui
**Issue - **
cp: cannot stat ‘/usr/local/hestia/install/deb/templates/web/skel/document_errors/*’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/firewall’: No such file or directory
(*) Generating default self-signed SSL certificate…
hst-install-ubuntu.sh: line 1080: /usr/local/hestia/bin/v-generate-ssl-cert: No such file or directory
(*) Adding SSL certificate to Hestia Control Panel…
sed: -e expression #1, char 3: unexpected ,'** **sed: -e expression #1, char 1: unknown command: ,'
(*) Configuring NGINX…
cp: cannot stat ‘/usr/local/hestia/install/deb/nginx/nginx.conf’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/nginx/status.conf’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/nginx/phpmyadmin.inc’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/nginx/phppgadmin.inc’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/logrotate/nginx’: No such file or directory
sed: can’t read /etc/nginx/nginx.conf: No such file or directory
sed: can’t read /usr/local/hestia/nginx/conf/nginx.conf: No such file or directory
Failed to start nginx.service: Unit nginx.service not found.
Error: nginx start failed
Please Help Me…
Let me guess: You tried to install the dpkg packages on a clean system? That was not the plan of the rc version. If you want to do a fresh install, checkout this one here: Some problems with 1.2.0 RC installation
Issue with File Manager Shared Below
OS -Debian 10
HestiaCP Version - 1.2.0-RC
Did you install the hestia-nginx and Hestia-php package?
Please check for the error in
/var/log/hestia/nginx-error.log
You need to install all beta packages ngx+php
wget https://apt.hestiacp.com/beta/hst-ubuntu-2004/hestia-nginx_1.17.10.deb
wget https://apt.hestiacp.com/beta/hst-ubuntu-2004/hestia-php_7.4.6.deb
dpkg -i hestia-nginx_1.17.10.deb
dpkg -i hestia-php_7.4.6.deb
apt-get install -f # to install missing required deps
“/usr/local/hestia/web/fm/dist/index.php” is not found (2: No such file or directory)
its Debian not Ubuntu…
I tried to reinstall packages you asked but still problem persists.
Run the installer
/usr/local/hestia/install/deb/filemanager/install-fm.sh
This will install the file manager. Think some thing went wrong during the install…
Saw you mentioned ubuntu in the first post
pardon… my mistake
two step verification automatically off… on Ubuntu 20.04 and H.CP 1.2.0 RC 1.
don’t know the reason, I just turn off the auto updates for hestiacp.
