Jail problem / help
Good day
I noticed that when creating a user with a tariff plan in which ssh access and jail limits are configured, a jail in the /srv/jail folder is not created for the user
I found a solution to the problem by running the script /usr/local/hestia/bin/v-rebuild-users via cron
But now after running the script, duplicates appear in the file /usr/local/hestia/data/queue/traffic.pipe every 30 minutes.
Ini grows endlessly.
And today, when I run the v-rebuild-users script, I get the error:
sed: -e expression #1, char 3: unknown command: ' sed: -e expression #1, char 3: unknown command:
Perhaps I am running the wrong command or I don’t understand something. Please tell me how to solve the problem. Thank you
This issue was resolved by deleting the user and restoring from a backup. But the issue of creating a jail for the user when it is created remains open. It is not created by itself. How can this problem be solved?
Please help me understand cgroup limits and how it all works. Where can I see through the console whether the limits have been applied to the user or not?
Should quotas be written to the slice folder? /sys/fs/cgroup/system.slice/srv-jail-decor268-home-decor268.mount
Because in the folder /etc/systemd/system.control/user-1007.slice.d there are certain limits for the user. But for some reason when running the php script for the load test they are not visible. The server cores are loaded at 100 percent. But the limit is 10 percent for the user.
inactive…
The command systemctl start user-1007.slice does not produce any results.
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
Does anyone understand this?
PLEASE HELP!
I can’t resolve the issue with quotas.
Are there any experts here on this subject?
Up)))))
Do not exit open ssh terminal under user via ssh client putty. Jail is enabled. Perhaps there are developers here who made cgroup and jail. I would like to help to set up this function. My system is Debian 12
In general, I figured out the slices. The slice starts itself when there is a load and any requests from the user. And it does not start because there are no requests.
The slice does not limit the work of the same php-fpm from the user. That is, fpm works as a separate slice and is not included in the restrictions for the user.
Well, in fact, the entire logic of cgoup’s work collapses here
Nothing is limited at all
Dear developers, pay attention to this.
For each user, in addition to the slice that is created, it is necessary to create a slice for PHP FPM
/etc/systemd/system/php-fpm-user-1004.service
[Unit]
Description=PHP FastCGI Process Manager for User 1004
After=network.target
[Service]
User=user1
Group=user1
ExecStart=/usr/sbin/php-fpm7.4 --nodaemonize --fpm-config /etc/php/7.4/fpm/pool.d/example.com.conf
Slice=user-1004.slice
[Install]
WantedBy=multi-user.target
Well, accordingly, when PHP is changed for the site, so that everything changes in the slice.
I am ready to join the testing and help finish this. Dear developers, if this is necessary for you, please give feedback.
We need to make it for each website unique then …
Yes. I think it is impossible to do it differently. But each slice will include general restrictions according to the package allocated to the user (resources)
I don’t know how applicable this is for mysql
The most important thing to limit is php fpm. Since it loads the processor and memory the most.
Mysql runs under a different user … so it will never work same as Nginx
Yes, I understand that. The easiest thing is to start limiting php fpm.
And don’t forget about [Bug] Jail is not created when creating a new user · Issue #4645 · hestiacp/hestiacp · GitHub I think this should be a pretty high-priority task - to figure out the restriction and creation of jail. This is purely my opinion. I’m ready to test it thoroughly after fixing it. The rest of the small bugs are not so important and can be fixed independently if you have the necessary knowledge)
Isn’t it ‘best practice’ to have a different user for each website?
I create users 20-40 at a time. And then use them as I get new domains / requests.
u101
u102
u103
u104
Then I use
customer1domain.com for u101.
I use
customer2domain.com for u102.
I’m perfectly able to allow multiple sub-domains to interact on the same site.
I’m kinda not familiar with cross-database mysql calls. I wish I could use MSSQL instead of mySQL :slight_smile:
I wish that the ‘auto-fill fields’ were able to persist a bit better. I don’t know how ‘autofill’ works on forms. I used to use Roboform to do this, but now every browser does it differently.
Yes but each domain need its own slice uniquely generated…
I think running mysql separately for each user is a very resource-intensive solution. It is not necessary.
In cloudlinux there is such a thing as MySQL Governor
It works yes.
In general, it is logical to do something similar but based on cgroup for mysql. Display the mysql limit settings for the entire server. You can specify how many resources to allocate to the database server. This will be quite enough
Example of implementation in the ispmanager 5+cloudlinux panel:
