Failed to restart after deploying wordpress and now gives this error
but syntax is ok
nginx: [emerg] no host in ":80" of the "listen" directive in /etc/nginx/conf.d/domains/koukisgas.gr.conf:8
nginx: configuration file /etc/nginx/nginx.conf test failed
nginx -t
root@koukis:/etc/nginx/conf.d#
does not declear server name in 192.168.1.20.conf
server {
listen 192.168.1.20:80 default_server;
server_name _;
access_log off;
error_log /dev/null;
phpMyAdmin - Error
Existing configuration file (/etc/phpmyadmin/config.inc.php) is not readable.
Hi @giormatsis,
To fix it:
chown -R root:www-data /etc/phpmyadmin/
chown -R hestiamail:www-data /usr/share/phpmyadmin/tmp/
Regarding the nginx error, I would like to debug it but meanwhile, to fix it, just edit these files:
/home/kkgs/conf/web/koukisgas.gr/nginx.conf
/home/kkgs/conf/web/koukisgas.gr/nginx.ssl.conf
Add your private ip to the listen
directive and once done, restart nginx:
systemctl restart nginx
GNU nano 7.2 /home/kkgs/conf/web/koukisgas.gr/nginx.conf
# Default Web Domain Template #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
# https://hestiacp.com/docs/server-administration/web-templates.html #
server {
listen 192.168.1.20:80;
server_name koukisgas.gr www.koukisgas.gr;
root /home/kkgs/web/koukisgas.gr/public_html;
access_log /var/log/nginx/domains/koukisgas.gr.log combined;
access_log /var/log/nginx/domains/koukisgas.gr.bytes bytes;
error_log /var/log/nginx/domains/koukisgas.gr.error.log error;
include /home/kkgs/conf/web/koukisgas.gr/nginx.forcessl.conf*;
server {
listen 192.168.1.20:443 ssl;
2024/05/21 03:28:24 [error] 3903#3903: *3276 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 3.137.198.96, server: koukisgas.gr, request: "GET /wp-json/wp/v2/product_cat/21 HTTP/>
2024/05/21 04:26:27 [error] 3903#3903: *3454 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 3.147.42.163, server: koukisgas.gr, request: "GET /wp-json/wp/v2/product_cat/39 HTTP/>
2024/05/21 04:46:00 [error] 3903#3903: *3499 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 3.137.164.210, server: koukisgas.gr, request: "GET /wp-json/wp/v2/product_cat/23 HTTP>
2024/05/21 05:04:31 [error] 79160#79160: *3517 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 102.165.48.97, server: koukisgas.gr, request: "GET /wp-login.php HTTP/2.0", upstrea>
2024/05/21 07:51:29 [error] 4014#4014: *1 directory index of "/home/kkgs/web/koukisgas.gr/public_html/" is forbidden, client: 171.67.70.238, server: koukisgas.gr, request: "GET / HTTP/1.1", host: "koukisgas.gr"
2024/05/21 07:51:29 [error] 4014#4014: *4 directory index of "/home/kkgs/web/koukisgas.gr/public_html/" is forbidden, client: 171.67.70.238, server: koukisgas.gr, request: "GET / HTTP/1.1", host: "www.koukisgas.gr"
2024/05/21 07:51:58 [error] 4014#4014: *5 directory index of "/home/kkgs/web/koukisgas.gr/public_html/" is forbidden, client: 37.6.251.120, server: koukisgas.gr, request: "GET / HTTP/2.0", host: "koukisgas.gr"
Execute this:
ping -c4 koukisgas.gr
If you see your public ip instead of the private ip, edit /etc/hosts
file and add in the first line this:
192.168.1.20 koukisgas.gr www.koukisgas.gr
Execute again the ping command and if you see the private ip, try to login to wordpress again.
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
127.0.1.1 koukis
127.0.0.1 koukis.koukisgas.gr
Error establishing a database connection
This either means that the username and password information in your wp-config.php file is incorrect or that contact with the database server at localhost could not be established. This could mean your hostβs database server is down.
Are you sure you have the correct username and password?
Are you sure you have typed the correct hostname?
Are you sure the database server is running?
nginx stays in staled state even after rebooting
i have to manual start it
root@koukis:~# systemctl status nginx --no-pager -l
β nginx.service - nginx - high performance web server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; preset: enabled)
Active: active (running) since Tue 2024-05-21 08:37:29 EEST; 4min 47s ago
Docs: https://nginx.org/en/docs/
Process: 4179 ExecStart=/usr/sbin/nginx -c /etc/nginx/nginx.conf (code=exited, status=0/SUCCESS)
Main PID: 4195 (nginx)
Tasks: 6 (limit: 8738)
CPU: 90ms
CGroup: /system.slice/nginx.service
ββ4195 "nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf"
ββ4197 "nginx: worker process"
ββ4198 "nginx: worker process"
ββ4199 "nginx: worker process"
ββ4200 "nginx: worker process"
ββ4201 "nginx: cache manager process"
May 21 08:37:29 koukis.koukisgas.gr systemd[1]: Starting nginx.service - nginx - high performance web server...
May 21 08:37:29 koukis.koukisgas.gr systemd[1]: Started nginx.service - nginx - high performance web server.
It is working fine from my side⦠I can see the setup page for wordpress.
me to
give the credentials
but no use throes the error
cleaned database and /web three times purged nginx restarted the server
no use
states this one
If you recreate/rebuild the web domain the conf will be modified again so you need to modify it again manually. I would like to debug it when have time.
changed to the default template no fastcgi and the only thing left is the user to get permissions to database because i gave an other user
but nginx does crazy things i have the feeling that this thing needs an expert to be solved
