No success in webmail
Hi
I get this when I visit my domains’ webmail page. But no roundcube!
I have tried re-installing roundcube on top of this installation but for some reason it is still not found at the webmail address
Check is your DNS settings are correct, and that you have a cname setting up as well.
Similar issue: Webmail Success Page
Check your ip in web settings it should be your public ip
Checked that.
Two host names appear. The internal hostname for that IP and my own domain name. Both with the same public IP, which I have leased from the hosting company
I think this might be my problem. I have added the hostname of the mail server as my domain name.
I tried renaming this in the web settings but domain field seems to be readonly. How could I change the domain name from mail.domain.com to domain.com ?
delete and recreate it is probaly the fastest way.
I’ve got active mail domains hanging under that mail host. I think deleting the host/domain in the control panel might cause problems for Hestiacp with “orphan” mail domains
Copy the email files and settings, take a backup as well. But otherwise that is the fastest way as Raphael suggested.
Tried that. Still no webmail app running. Just the Success page showing. Incidentally, none of the mail domains have webmail. As if it never got installed or server not redirecting webmail queries to the actual app
I moved one domain to another server, and I am stuck at this too. My original server was from 1.8.2, and the new one is at 1.9.4. No issues in the old server, but something is amiss in the 1.9.4. I am stuck trying for the last 17 hours now (sleep time aside).
Cache does not seem to be the issue as I am getting “this site is under construction” page
Curl gives me the correct response though:
curl webmail.panel.domain.tld
Roundcube Webmail :: Welcome to Roundcube Webmail
Very odd… :frowning:
“We’re working on it!” means that there was a website found and shows the default text. On your case, it looks like you try to visit cp.flossboxin.org.in, which doesnt seem webmail.panel.domain.tl. When curl works, its probaly still a caching issue (which usualy should not hold back more than 17hrs, try other uplinks like mobile phone).
