Not receiving emails in roundcube
Hello
I have added all 7 DNS records that hestiacp asks to add.
No DNS record is proxied in cloudflare.
I have opened these ports:
25, 465, 587
8083, 80, 443 (for hestiacp)
993, 143, 995, 110
Still, I am not receiving emails. :neutral_face:
Hi @laura,
You should check the logs to know what is going on.
/var/log/exim4/mainlog
But if you receive no mails at all, I suppose it is because you are using 1.1.1.1 as your DNS resolver.
If that is the case you have 4 options:
1.- Use other resolver (that is not being blocked by spamhaus) instead of Cloudflare ones (1.1.1.1, 1.0.0.1).
2.- Install and use your own dns resolver (like Unbound or PowerDNS).
3.- Remove zen.spamhaus.org from /etc/exim4/dnsbl.conf and restart exim (I don’t recommend it)
4.- Create a free query key from spamhaus and use it in exim. To do so, check this link
I was using Cloudflare’s 1.1.1.1 as DNS resolver.
Now, I changed DNS to Google DNS- The Best Free and Public DNS Servers (2024)
8.8.8.8
8.8.4.4
Still when i send email from “Gmail” to “HestiaCP webmail”, it is rejecting.
like this;
Message blocked
Your message to [email protected] has been blocked.
Show the output of this command (no output means your dns resolver is not being blocked):
dig 1.0.0.1.zen.spamhaus.org +short
Again, you must check the Exim logs as I said in previous post.
I did this:
  1. SSH into Virtual machine
  2. sudo su -
  3. dig 1.0.0.1.zen.spamhaus.org +short
It shows- 127.255.255.254
Then it is being blocked by spamhaus and you won’t receive any mail.
Are you sure you changed your dns?
cat /etc/resolv.conf
Yes. I have changes DNS in my Windows laptop (Control Panel > Network and Internet …)
I also rechecked whether I have changed or not in Windows Settings.
When I run this command cat /etc/resolv.conf after SSH into VM, it shows this:
root@panel:~# cat /etc/resolv.conf
This is /run/systemd/resolve/stub-resolv.conf managed by man:systemd-resolved(8).
Do not edit.
This file might be symlinked as /etc/resolv.conf. If you’re looking at
/etc/resolv.conf and seeing this text, you have followed the symlink.
This is a dynamic resolv.conf file for connecting local clients to the
internal DNS stub resolver of systemd-resolved. This file lists all
configured search domains.
Run “resolvectl status” to see details about the uplink DNS servers
currently in use.
Third party programs should typically not access this file directly, but only
through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a
different way, replace this symlink by a static file or a different symlink.
See man:systemd-resolved.service(8) for details about the supported modes of
operation for /etc/resolv.conf.
nameserver 127.0.0.53
options edns0 trust-ad
search ap-south-1.compute.internal
No, you must change it in your server.
Show the output of:
cat /etc/systemd/resolved.conf
root@panel:~# cat /etc/systemd/resolved.conf
This file is part of systemd.
systemd is free software; you can redistribute it and/or modify it under the
terms of the GNU Lesser General Public License as published by the Free
Software Foundation; either version 2.1 of the License, or (at your option)
any later version.
Entries in this file show the compile time defaults. Local configuration
should be created by either modifying this file, or by creating "drop-ins" in
the resolved.conf.d/ subdirectory. The latter is generally recommended.
Defaults can be restored by simply deleting this file and all drop-ins.
Use 'systemd-analyze cat-config systemd/resolved.conf' to display the full config.
See resolved.conf(5) for details.
[Resolve]
Some examples of DNS servers which may be used for DNS= and FallbackDNS=:
Cloudflare: 1.1.1.1 cloudflare-dns. com 1.0.0.1 cloudflare-dns. com 2606:4700:4700::1111 cloudflare-dns. com 2606:4700:4700::1001 cloudflare-dns. com
Google:     8.8.8.8 dns.google 8.8.4.4 dns.google 2001:4860:4860::8888 dns.google 2001:4860:4860::8844 dns.google
Quad9:      9.9.9.9 dns.quad9. net 149.112.112.112 dns.quad9. net 2620:fe::fe dns.quad9. net 2620:fe::9 dns.quad9. net
DNS=
FallbackDNS=
Domains=
DNSSEC=no
DNSOverTLS=no
MulticastDNS=no
LLMNR=no
Cache=no-negative
CacheFromLocalhost=no
DNSStubListener=yes
DNSStubListenerExtra=
ReadEtcHosts=yes
ResolveUnicastSingleLabel=no
Edit the file and modify
DNS=
to
DNS=8.8.8.8
Save the file and restart systemd-resolved
systemctl restart systemd-resolved
Check again /etc/resolv.conf file, you should see a line with nameserver 8.8.8.8
If you don’t see it, show me the output of this command and I’ll show you other way to change it:
systemctl status resolvconf.service
Now, it is showing this
DNS=8.8.8.8
FallbackDNS=
Domains=
DNSSEC=no
DNSOverTLS=no
Ok.
Did you run systemctl restart systemd-resolved?
Show:
I run systemctl restart systemd-resolved
root@panel:~# systemctl restart systemd-resolved
Do not edit.
currently in use.
Show me the output of:
root@panel:~# systemctl status resolvconf.service
Unit resolvconf.service could not be found.
apt install resolvconf
echo 'nameserver 8.8.8.8' >> /etc/resolvconf/resolv.conf.d/head
resolvconf -u
systemctl restart resolvconf
After that check again /etc/resolv.conf
Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
DO NOT EDIT THIS FILE BY HAND – YOUR CHANGES WILL BE OVERWRITTEN
127.0.0.53 is the systemd-resolved stub resolver.
run “systemd-resolve --status” to see details about the actual nameservers.
nameserver 8.8.8.8
Great.
Now check again with dig:
If no output all should be good, try to send a mail to your server.
no output. sending mail to server…
yes. i am getting email. thanks a lot.
can you explain in short what you were telling?
i have no idea what i was doing.
