is there a way to use hestia with other webmail clients also installed with hestia would that be possible?
we support rainloop and roundcube, you can adjust the mail client in mail settings.
Install your wanted mail client in
/var/lib/
Make sure www-data has read access
Create templates in:
Depending on your setup:
for mailclient.tpl and stpl
default_mailclient.tpl and stpl
or for “nginx only”
https://github.com/hestiacp/hestiacp/blob/main/install/deb/templates/mail/nginx/mailclient.tpl and stpl
Modify /usr/local/hestia/conf/hestia.conf line:
WEBMAIL_SYSTEM=‘roundcube,rainloop’
to WEBMAIL_SYSTEM=‘roundcube,rainloop,mailclient’
Yeah its becuase i only see the roundcube client so i was asking but thanks
Getting this ![]()
change to $HESTIA/bin and run ./v-add…
I am still getting the error
Type ./ Before the command
thanks
