I have Ubuntu 20.04+HestiaCP 1.3.0 on old server. I want to migrate my website and database to a new server with Ubuntu 20.04+HestiaCP 1.3.0 too.
After I do backup on old server, I upload files manually to the new server (ftp). Problems comes when I import database from old server to the new server via phpMyAdmin.
Charaters from my language are not working " š đ č ć ž ", but it’s same charset (utf8 db type) on both (old and new) servers.
When I login to phpmyadmin on old server, I get fu*ked up charaters too. But somehow the website displays them as normal, and everything works fine:
if you just want to migrate to new server, why you not just made a simple backup and restore if you use the same OS an same Hestia as control panel. what i mean is using command line
if got problem using this commandline, there are solution on this forum
if i am not wrong is this
i always use this method all the time and no issue
@Raphael both servers (old and new) are with same OS and same Hestia version, also both databases are created with ut8.
@jtdoank I’ve tried that too. Created new user, uploaded backup and did a restore via panel. But same thing happens with database. On the new server the letters š đ ž č ć are not working.
Here is a sample of info inside old server (where the db is working correctly):
It’s using same locales. But when we talk about that, it would be good for hestiacp to generate needed locale for it. Eg to set default EN_US.UTF-8 by automatic.
