Release data for version Ver 1.1
1- i have downloaded the 1.1.0 before the fix is maybe why i dont have the bash file but i have download it from git and run it so MultiPHP is installed now.
2- About One Click Apps is possible include WHMCS? i try install on Vesta long time ago and was very difficult.
WHMCS is very polupar billing system for hosting.
Probably not, WHMCS depends on ioncube and I could not even find a way to download the software.
The main motivation behind ā€˜Quick install Apps’ functionality was to help sysadmins reduce time spent on repetitive tasks like installing wordpress, opencart or a couple of other apps over and over again for every customer. Apps that get installed a single time per server are outside of that scope.
You can rerun the deb package installation and it will bring you the current file(s) that you’re missing.
Based on the reasons @Lupu already wrote, we will not support WHMCS in quick installer.
Hi guys,
firts of all i want to thank you for your amazing work and time spent.
I’m considering to switch from VESTA to HESTIA (for many reasons) so i start to test HESTIA 1.1.0 yesterday and i try to help.
Yesterday i’ve tried a fresh new installation on DEBIAN 10, not just upgrading HESTIA, from MASTER GIT and it works fine to me. Multi-php as well.
I’ve play with backups (local and ftp), web, SSL and some settings like frontend template, db, rebooting, etc.
All is ok.
I let you know if i find something else.
Keep doing and let’s make HESTIA solid and stable! :slight_smile:
Thanks again,
Ubi
Hi Ubi
Thanks for your awesome testing, glad all works properly and you’re happy with Hestia!
Please let us know, if you find anything to fix :slight_smile:!
PS: Hestia is still compatible to vesta backups, you just can import them using v-restore-user.
Hi @Raphael , you are welcome! And thank you for the tip :wink:
Good evening everyone.
My name is Eugene, I am from Ukraine.
I do not know English well, therefore, I apologize if I sometimes make mistakes in writing sentences.
I installed Hestia version 1.1.0, everything got up without problems, I will test it in the near future. If I find any bugs - I will write to this forum thread.
I have a question. I have a need to connect IonCube Loader. I use OpenCart, some modules for this CMS require IonCube Loader. How can i do this ?
Please follow the official steps from ioncube, hestia doesnt need any special steps.
I am testing 1.1 with Debian 9 and Hetzner
In roundcube, I cannot add email or other info at contacts
Way to less information, please add more details, what steps you do, which logs you already checked. For bug reporting, please add a issue on our github and follow the guidelines: https://github.com/hestiacp/hestiacp/issues/new
@falzo still using Hestiacp, currently installing a fresh ver 1.1.0 on Debian 10.while I have quite a bit of spare time now.
I will replicate my 1.0.6 install which has all PCI compliance requirements, additional requirements such as Brotli, Rayzor, Pyzor, DCC, Webp, ImageMagick that are all additional built from source
awesome! let us know how it goes :wink:
@falzo Everything installed fine on fresh install of 1.1.0 on Debian 10 using the alternative install without release first, did not run into any issues,
I did notice Records next to the logo is still there and points to users so not sure what that is for exactly maybe a place holder.
Now testing Debian 9 the same.
Hi guys!
I am a bit confused. HestiaCP v1.1.0 is already released or not yet? The website shows that the latest version is v1.0.6 and here people are talking about updating to v1.1.0 (or that is a beta version?). If it is not released yet, when it will be? Thank you!
1.1.0 is currently in testing state, as soon as we’ve got enough feedback, we will place the new release on our repository. Can’t tell you an exact date yet.
Thank your for your answer. After reading the discussion, it seems pretty stable. I am planning to update to the testing version soon, because there are a few features which i would really love to use. After releasing v1.1.0 there will be an option to ā€œmove backā€ from testing versions to stable updates? or i have to reinstall it? Thanks!
Currently, there is no way back - so you would need to reinstall. Personally I can say, all is working properly: My productive systems are running with 1.1.0 since a few days.
Also my production server is running fine from few days with hestia 1.1.0 and i dont found any issue.
Basically what i understand between candidate and final y same not need re install only need re install if candidate version has some bug and it is fixed otherwise @ outwork can keep it running.
That is right?
That’s right, you can just reinstall the 1.1.0 deb package if a new ā€œversionā€ of it has been released, that’s not a problem.
Hi Guys,
after almost a week of testing HST 1.1.0 / Debian 10 i can’t see any issue on regular tasks.
I’m just facing a small issue during restore backups from VESTA. Any backup i try to resotre in HESTIA is giving me this error :slight_smile:
Once i got this error, if i go on HESTIA panel , i can see the new user and website restored, but i’m not sure restore is complete. Mail domain is missing as example.
Maybe i’m doing something wrong, i don’t know.
Actions i’m doing -
As ROOT, i launch the command V-RESTORE-USER new [backup file] and i got the message above.
The same if i set the user instead on ā€œnewā€ parameter.
Additional, i’m not able to find the logs for this (
Thank you and let me know if you need some other info.
Great job btw :slight_smile:
