I don’t use email on the VPS and the clamav-daemon and spamd services are consuming around 2.5GB RAM.
Just by stopping the service it activates when restarted.
How to remove without damaging HestiaCP?
The web interface background can stop running related programs. You can log in to the hestia panel to manage and view: 8083/list/server/
The service it activates when Debian 12 restarted. Is there a way to not start when restarting the operating system?
If reinstalling is not troublesome, it is recommended to reinstall hestia. Choose not to install unnecessary components. If it is troublesome, it is recommended to remove it from the relevant configuration of hestia (this may usually cause crash due to misoperation). If the amount of data is not large, it is recommended to reinstall
If you are worried about losing access, you can choose to order a new server that can be cancelled at any time. Then, after the existing data is successfully imported into the new server, resolve the domain IP to the new server. Then reset the original server data. This way, the experience (viewer) will not be interrupted.
There is no need to reinstall.
systemctl disable spamd
systemctl stop spamd
systemctl disable clamav-daemon
systemctl stop clamav-daemon
v-change-sys-config-value ANTIVIRUS_SYSTEM ''
v-change-sys-config-value ANTISPAM_SYSTEM ''
Edit exim4 conf /etc/exim4/exim4.conf.template and comment these lines:
Before:
SPAMASSASSIN = yes
SPAM_SCORE = 50
SPAM_REJECT_SCORE = 100
CLAMD = yes
After:
#SPAMASSASSIN = yes
#SPAM_SCORE = 50
#SPAM_REJECT_SCORE = 100
#CLAMD = yes
Save the file and restart exim.
systemctl restart exim4
Technically only having out CLAMD / SPAMASSASSIN is enough but should not matter to do the rest …
There is zero reasons to reinstall it … Unless you like to waste your time…
