Resolving disk space issues on my VPS
Today I found my VPS disk full. I could not log in to HestiaCP, IMAP or Roundcube. Not even the user admin via SSH could create temporary files to operate. I downloaded the 3 backups using scp and deleted them to free up space. After that I restarted and finally I could log in.
Then I followed the tutorial Resolving Disk Space issues on a VPS / Dedicated server and the disk occupation has remained at 48% after deleting several 5 GB log files.
Does HestiaCP have any tool to perform this process? I was not able to find it. Would it be possible to add it?
Depends on which log files you’ve deleted, usualy the logs should have a few mb, not 5 gb.
I’ve deleted these files:
5.3G /var/log/syslog.1
5.3G /var/log/daemon.log
4.1G /var/log/clamav/freshclam.log-20200217_132103
Did you checked what the content or some parts if it? They are srsly to big, which could point to a issue with the system, maybe you can check the current files for any abnormal parts.
to add to that, usually logrotate takes care of compressing and even removing old logfiles after a certain amount of time. seeing syslog.1 in your list makes me guess it works like expected on your system…
BUT, your box might have seen a brute force attack or some other incident which made the log-files grow very quickly in a short amount of time. so you definitely should follow @Raphael s advice and try to investigate… aka READ these logs :wink:
So far I have not seen anything suspicious. I will continue watching them.
Thank you.
This seems to be related to a ClamAV problem. Hundreds of lines appear in syslog and daemon.log:
root@mail:/home/admin# cat /var/log/syslog.1| grep Malformed
Feb 22 16:25:31 mail freshclam[951]: Sat Feb 22 16:25:31 2020 -> ^[LibClamAV] Can't load daily.hsb: Malformed database
Feb 22 16:25:31 mail freshclam[951]: Sat Feb 22 16:25:31 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-0f5c43861d7584667417f38ced9727f5.tmp-daily.cld: Malformed database
Feb 22 16:25:31 mail freshclam[951]: Sat Feb 22 16:25:31 2020 -> !Failed to load new database: Malformed database
Feb 22 17:25:38 mail freshclam[951]: Sat Feb 22 17:25:38 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1155587
Feb 22 17:25:38 mail freshclam[951]: Sat Feb 22 17:25:38 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-068909abd171768f89c40e1569fdc31e.tmp-daily.cld: Malformed database
Feb 22 17:25:38 mail freshclam[951]: Sat Feb 22 17:25:38 2020 -> !Failed to load new database: Malformed database
Feb 22 18:25:45 mail freshclam[951]: Sat Feb 22 18:25:45 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1155587
Feb 22 18:25:45 mail freshclam[951]: Sat Feb 22 18:25:45 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-89e3cb2dd47ac723a6ee87051b73b90c.tmp-daily.cld: Malformed database
Feb 22 18:25:45 mail freshclam[951]: Sat Feb 22 18:25:45 2020 -> !Failed to load new database: Malformed database
Feb 22 19:25:53 mail freshclam[951]: Sat Feb 22 19:25:53 2020 -> ^[LibClamAV] Can't load daily.hsb: Malformed database
Feb 22 19:25:53 mail freshclam[951]: Sat Feb 22 19:25:53 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-8a80d96c081b2238b974aa425db1a646.tmp-daily.cld: Malformed database
Feb 22 19:25:53 mail freshclam[951]: Sat Feb 22 19:25:53 2020 -> !Failed to load new database: Malformed database
Feb 22 20:26:00 mail freshclam[951]: Sat Feb 22 20:26:00 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1158542
Feb 22 20:26:00 mail freshclam[951]: Sat Feb 22 20:26:00 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-058dda19d2f23d673eee5bce68aced9e.tmp-daily.cld: Malformed database
Feb 22 20:26:00 mail freshclam[951]: Sat Feb 22 20:26:00 2020 -> !Failed to load new database: Malformed database
Feb 22 21:26:08 mail freshclam[951]: Sat Feb 22 21:26:08 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1164532
Feb 22 21:26:08 mail freshclam[951]: Sat Feb 22 21:26:08 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-f7def1be8282325638b058ad9491e1aa.tmp-daily.cld: Malformed database
Feb 22 21:26:08 mail freshclam[951]: Sat Feb 22 21:26:08 2020 -> !Failed to load new database: Malformed database
Feb 22 22:26:31 mail freshclam[951]: Sat Feb 22 22:26:31 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1192476
Feb 22 22:26:31 mail freshclam[951]: Sat Feb 22 22:26:31 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-001d63d4e78457d6483401430c63c605.tmp-daily.cld: Malformed database
Feb 22 22:26:31 mail freshclam[951]: Sat Feb 22 22:26:31 2020 -> !Failed to load new database: Malformed database
Feb 22 23:27:01 mail freshclam[951]: Sat Feb 22 23:27:01 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1250779
Feb 22 23:27:01 mail freshclam[951]: Sat Feb 22 23:27:01 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-bb32c824af9ee97ccc041edc6e2aa361.tmp-daily.cld: Malformed database
Feb 22 23:27:01 mail freshclam[951]: Sat Feb 22 23:27:01 2020 -> !Failed to load new database: Malformed database
Feb 23 00:27:32 mail freshclam[951]: Sun Feb 23 00:27:32 2020 -> ^[LibClamAV] Can't load daily.hsb: Malformed database
Feb 23 00:27:32 mail freshclam[951]: Sun Feb 23 00:27:32 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-b69d10cce261c747dfcd742e91f017bf.tmp-daily.cld: Malformed database
Feb 23 00:27:32 mail freshclam[951]: Sun Feb 23 00:27:32 2020 -> !Failed to load new database: Malformed database
Feb 23 01:28:00 mail freshclam[951]: Sun Feb 23 01:28:00 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1250779
Feb 23 01:28:00 mail freshclam[951]: Sun Feb 23 01:28:00 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-13f5b884bb2860994a10f53f8427ed70.tmp-daily.cld: Malformed database
Feb 23 01:28:00 mail freshclam[951]: Sun Feb 23 01:28:00 2020 -> !Failed to load new database: Malformed database
Feb 23 02:28:29 mail freshclam[951]: Sun Feb 23 02:28:29 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1265691
Feb 23 02:28:29 mail freshclam[951]: Sun Feb 23 02:28:29 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-92269043eee7e9e5940f7feea613beff.tmp-daily.cld: Malformed database
Feb 23 02:28:29 mail freshclam[951]: Sun Feb 23 02:28:29 2020 -> !Failed to load new database: Malformed database
Feb 23 03:28:58 mail freshclam[951]: Sun Feb 23 03:28:58 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1262755
Feb 23 03:28:58 mail freshclam[951]: Sun Feb 23 03:28:58 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-fab41eff4999233ad46615056189ec45.tmp-daily.cld: Malformed database
Feb 23 03:28:58 mail freshclam[951]: Sun Feb 23 03:28:58 2020 -> !Failed to load new database: Malformed database
Feb 23 04:29:27 mail freshclam[951]: Sun Feb 23 04:29:27 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1260234
Feb 23 04:29:27 mail freshclam[951]: Sun Feb 23 04:29:27 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-415612e07c6b3e9a7372efe70ddfaef4.tmp-daily.cld: Malformed database
Feb 23 04:29:27 mail freshclam[951]: Sun Feb 23 04:29:27 2020 -> !Failed to load new database: Malformed database
Feb 23 05:29:56 mail freshclam[951]: Sun Feb 23 05:29:55 2020 -> ^[LibClamAV] cli_loadhash: Malformed hash string at line 1253975
Feb 23 05:29:56 mail freshclam[951]: Sun Feb 23 05:29:55 2020 -> ^[LibClamAV] Can't load /var/lib/clamav/tmp/clamav-362eef3fb267c9aa6eed7aefce99479e.tmp-daily.cld: Malformed database
Feb 23 05:29:56 mail freshclam[951]: Sun Feb 23 05:29:55 2020 -> !Failed to load new database: Malformed database
Will I cause a disaster if I follow these instructions to reinstall ClamAV and fix it?
Should I do it from the admin or root account?
It took me just a second to google it, I would follow this here first: https://www.howtoforge.com/community/threads/clamav-database-update-error.76634/
Great! Everything seems to work now. The databases file extension changed from “* .cld” to “* .cvd”. These were the commands I used:
cd /var/lib/clamav/
ls -l
mv daily.cld daily.cld.old
mv main.cld main.cld.old
ls -l
systemctl restart clamav-freshclam
cat /var/log/clamav/freshclam.log
cat /var/log/clamav/clamav.log
Thank you very much.
