sv3n
1
how can I change the skin of roundcoube? To classic
eris
2
You will need to upgrade Roundcube version.
We are working on changes to the software to update to the last version
sv3n
3
you can’t do that manually either?
Raphael
4
You can do it manualy, but currently we do not officially support that way. Search for roundcube in our forum, a community member provided a tutorial.
sv3n
5
Hmm… sorry i can not find
jtdoank
6
Perhaps this can help you out
Just a quick note to sv3n, I did use the upgrade instructions to manually install roundcube 1.4.10 without any issue. I’m on Deb 9.
