I know there is a a fix for this, but I can’t for the life of me find it again! I’m trying to use Roundcube on a server I set up a while ago. With one of the installers, it didn’t do something right around enabling a module of some sorts. I seem to remember its just a case of running a command or 2 … but I can’t remember which modules it was!
Does anyone remember? Currently all I get is the PHP source code showing at webmail.mysite.com
Cheers
Andy
sahsanu
February 22, 2024, 12:20pm
2
If you mean mpm apache modules, check what is the mpm you are using:
apache2ctl -M 2>/dev/null | grep mpm
If you are using mpm_prefork
, the you should disable it and enable mpm_event
a2dismod mpm_prefork
a2enmod mpm_event
systemctl restart apache2
Thanks. Unfortunately I now get this on all sites:
or] 2950595#2950595: *63988 upstream prematurely closed connection while reading response header from upstream, client: 81.174.134.33, server: deor.nl, request: “GET /favicon.ico HTTP/2.0”, upstream: “https://172.105.244.200:8443/favicon.ico ”, host: “deor.nl”, referrer: “https://deor.nl/ ”
I’m using apache + ngninx
mpm_event_module (shared)
in /var/log/apache2/error.log , I see:
[Thu Feb 22 12:27:33.619135 2024] [core:notice] [pid 2969247:tid 140141788768128] AH00051: child pid 2970036 exit signal Abort (6), possible coredump in /etc/apache2
sahsanu
February 22, 2024, 12:29pm
4
php -v
find /etc/php -name "www.conf"
lsof -Pn +c0 -i:9000 -sTCP:LISTEN
php -v
PHP 8.2.8 (cli) (built: Jul 8 2023 07:10:21) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.8, Copyright (c) Zend Technologies
with Zend OPcache v8.2.8, Copyright (c), by Zend Technologies
/etc/php/8.2/fpm/pool.d/www.conf
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
php-fpm8.2 2967207 root 10u IPv4 234883350 0t0 TCP 127.0.0.1:9000 (LISTEN)
BTW, reversing the process again - ie
a2dismod mpm_event
a2enmod mpm_prefork
the sites come back up, but roundcube doesn’t work again
sahsanu
February 22, 2024, 12:34pm
6
Ok, show the output of these commands:
cat /etc/php/8.2/fpm/pool.d/www.conf
cat /etc/apache2/conf.d/hestia-event.conf
If the last cat doesn’t work:
cp /usr/local/hestia/install/deb/apache2/hestia-event.conf /etc/apache2/conf.d/
Disable mpm_prefork, enable mpm_event and restart apache2
Here you go:
root@bb:/home/deor/web/deor.nl/logs# cat /etc/php/8.2/fpm/pool.d/www.conf
; origin-src: deb/php-fpm/www.conf
[www]
listen = 127.0.0.1:9000
listen.allowed_clients = 127.0.0.1
user = hestiamail
group = www-data
pm = ondemand
pm.max_children = 4
pm.max_requests = 4000
pm.process_idle_timeout = 10s
root@bb:/home/deor/web/deor.nl/logs# cat /etc/apache2/conf.d/hestia-event.conf
<IfModule mpm_event_module>
<FilesMatch \.php$>
SetHandler "proxy:fcgi://127.0.0.1:9000"
</FilesMatch>
</IfModule>r
sahsanu
February 22, 2024, 12:46pm
8
That looks fine, apache is now using mpm_event or mpm_prefork?
What’s the result of this command:
diff -u /usr/local/hestia/install/deb/apache2/apache2.conf /etc/apache2/apache2.conf
What problems did you have installing Hestia?
eris
February 22, 2024, 1:08pm
9
Don’t forget to rebuild mail domains
Had the same issues last night including with the"Hestia" server last night…
Thanks all. Sorry, I had to go out for lunch So for that command @sahsanu
--- /usr/local/hestia/install/deb/apache2/apache2.conf 2023-11-27 19:40:32.000000000 +0000
+++ /etc/apache2/apache2.conf 2023-08-11 12:46:12.188674862 +0000
@@ -74,8 +74,8 @@
Include ports.conf
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
-LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
-LogFormat "%h %l %u %t \"%r\" %>s %O" common
+LogFormat "%a %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
+LogFormat "%a %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
LogFormat "%b" bytes
@eris Any particular command? I tried doing it as an admin in the GUI, and selected all > rebuild all. But still gives a 500 IS error with:
2024/02/22 13:56:08 [error] 2969693#2969693: *7013 upstream prematurely closed connection while reading response header from upstream, client: 81.174.134.33, server: deor.nl, request: "GET /favicon.ico/ HTTP/2.0", upstream: "https://172.105.244.200:8443/favicon.ico/", host: "www.deor.nl", referrer: "https://www.deor.nl/"
eris
February 22, 2024, 2:04pm
11
Probably it takes to long as the connection has been closed (I think it is bij default 30 or 60 seconds)
Als the main reason why we removed the possibility to update via web ui…
sahsanu
February 22, 2024, 2:25pm
12
andrewnewby:
v-rebuild-mail-domain USER DOMAIN
or
v-rebuild-mail-domains USER
If you want to rebuild all (mail, web, dns, etc.):
v-rebuild-all USER yes
The last yes
is to restart the services:
Unfortunately I still get a 500 IS error I’ll have another play when I can. The issue is that this is a live server, and every time it comes up with 500 IS errors for end users, I get complaints For the moment, only the webmail doesn’t work - so I may just have to put up with that
Coming back to this, I can’t figure it out still. I’m comparing files. /var/lib/roundcube on the server that isn’t working, had files as root:root. I’ve looked at 2 other server (where it works), and it was root:hestiamail. So I’ve sorted that. But it still doesn’t run.
What config actually tells the webmail domain to run the PHP? Comparing 2 sites mail config files for nginx, I see:
This webmail one works (on another server)
server {
listen 172.233.60.35:80;
listen [::]:80;
server_name webmail.zichtopmedia.nl mail.zichtopmedia.nl;
root /var/lib/roundcube;
access_log /var/log/nginx/domains/webmail.zichtopmedia.nl.log combined;
error_log /var/log/nginx/domains/webmail.zichtopmedia.nl.error.log error;
include /home/zichtopmed/conf/mail/zichtopmedia.nl/nginx.forcessl.conf*;
deny all;
return 404;
location ~ ^/(README.md|config|temp|logs|bin|SQL|INSTALL|LICENSE|CHANGELOG|UPGRADING)$ {
deny all;
return 404;
location / {
alias /var/lib/roundcube/;
try_files $uri $uri/ =404;
proxy_pass http://172.233.60.35:8080;
expires 7d;
location @fallback {
location /error/ {
alias /var/www/document_errors/;
include /home/zichtopmed/conf/mail/zichtopmedia.nl/nginx.conf_*;
This one doesn’t (on the new server)
server {
listen 172.105.244.200:80;
listen [::]:80;
server_name webmail.businessbookers.nl mail.businessbookers.nl;
access_log /var/log/nginx/domains/webmail.businessbookers.nl.log combined;
error_log /var/log/nginx/domains/webmail.businessbookers.nl.error.log error;
include /home/businessbo/conf/mail/businessbookers.nl/nginx.forcessl.conf*;
deny all;
return 404;
deny all;
return 404;
location / {
proxy_pass http://172.105.244.200:8080;
expires 7d;
location /error/ {
include /home/businessbo/conf/mail/businessbookers.nl/nginx.conf_*;
So apart from the IP’s being different and the paths (username and domain), I don’t see any difference.
Hmmm there must be something else going on.
mpm_prefork is disabled - mpm_event is enabled. Apache is restarted:
root@bb:/etc/apache2/mods-enabled# ls -lh
total 4.0K
lrwxrwxrwx 1 root root 36 Aug 11 2023 access_compat.load -> ../mods-available/access_compat.load
lrwxrwxrwx 1 root root 30 Aug 11 2023 actions.conf -> ../mods-available/actions.conf
lrwxrwxrwx 1 root root 30 Aug 11 2023 actions.load -> ../mods-available/actions.load
lrwxrwxrwx 1 root root 28 Aug 11 2023 alias.conf -> ../mods-available/alias.conf
lrwxrwxrwx 1 root root 28 Aug 11 2023 alias.load -> ../mods-available/alias.load
lrwxrwxrwx 1 root root 33 Aug 11 2023 auth_basic.load -> ../mods-available/auth_basic.load
lrwxrwxrwx 1 root root 33 Aug 11 2023 authn_core.load -> ../mods-available/authn_core.load
lrwxrwxrwx 1 root root 33 Aug 11 2023 authn_file.load -> ../mods-available/authn_file.load
lrwxrwxrwx 1 root root 33 Aug 11 2023 authz_core.load -> ../mods-available/authz_core.load
lrwxrwxrwx 1 root root 38 Aug 11 2023 authz_groupfile.load -> ../mods-available/authz_groupfile.load
lrwxrwxrwx 1 root root 33 Aug 11 2023 authz_host.load -> ../mods-available/authz_host.load
lrwxrwxrwx 1 root root 33 Aug 11 2023 authz_user.load -> ../mods-available/authz_user.load
lrwxrwxrwx 1 root root 32 Aug 11 2023 autoindex.conf -> ../mods-available/autoindex.conf
lrwxrwxrwx 1 root root 32 Aug 11 2023 autoindex.load -> ../mods-available/autoindex.load
lrwxrwxrwx 1 root root 26 Aug 11 2023 cgi.load -> ../mods-available/cgi.load
lrwxrwxrwx 1 root root 30 Aug 11 2023 deflate.conf -> ../mods-available/deflate.conf
lrwxrwxrwx 1 root root 30 Aug 11 2023 deflate.load -> ../mods-available/deflate.load
lrwxrwxrwx 1 root root 26 Aug 11 2023 dir.conf -> ../mods-available/dir.conf
lrwxrwxrwx 1 root root 26 Aug 11 2023 dir.load -> ../mods-available/dir.load
lrwxrwxrwx 1 root root 26 Aug 11 2023 env.load -> ../mods-available/env.load
lrwxrwxrwx 1 root root 28 Aug 11 2023 fcgid.conf -> ../mods-available/fcgid.conf
lrwxrwxrwx 1 root root 28 Aug 11 2023 fcgid.load -> ../mods-available/fcgid.load
lrwxrwxrwx 1 root root 29 Aug 11 2023 filter.load -> ../mods-available/filter.load
lrwxrwxrwx 1 root root 36 Aug 11 2023 hestia-status.conf -> ../mods-available/hestia-status.conf
lrwxrwxrwx 1 root root 36 Aug 11 2023 hestia-status.load -> ../mods-available/hestia-status.load
lrwxrwxrwx 1 root root 27 Aug 11 2023 mime.conf -> ../mods-available/mime.conf
lrwxrwxrwx 1 root root 27 Aug 11 2023 mime.load -> ../mods-available/mime.load
lrwxrwxrwx 1 root root 32 Feb 23 13:54 mpm_event.conf -> ../mods-available/mpm_event.conf
lrwxrwxrwx 1 root root 32 Feb 23 13:54 mpm_event.load -> ../mods-available/mpm_event.load
lrwxrwxrwx 1 root root 34 Aug 11 2023 negotiation.conf -> ../mods-available/negotiation.conf
lrwxrwxrwx 1 root root 34 Aug 11 2023 negotiation.load -> ../mods-available/negotiation.load
lrwxrwxrwx 1 root root 27 Aug 11 2023 perl.load -> ../mods-available/perl.load
lrwxrwxrwx 1 root root 28 Aug 11 2023 proxy.conf -> ../mods-available/proxy.conf
lrwxrwxrwx 1 root root 33 Aug 11 2023 proxy_fcgi.load -> ../mods-available/proxy_fcgi.load
lrwxrwxrwx 1 root root 28 Aug 11 2023 proxy.load -> ../mods-available/proxy.load
lrwxrwxrwx 1 root root 31 Aug 11 2023 remoteip.conf -> ../mods-available/remoteip.conf
lrwxrwxrwx 1 root root 31 Aug 11 2023 remoteip.load -> ../mods-available/remoteip.load
lrwxrwxrwx 1 root root 33 Aug 11 2023 reqtimeout.conf -> ../mods-available/reqtimeout.conf
lrwxrwxrwx 1 root root 33 Aug 11 2023 reqtimeout.load -> ../mods-available/reqtimeout.load
lrwxrwxrwx 1 root root 30 Aug 11 2023 rewrite.load -> ../mods-available/rewrite.load
-rw-r--r-- 1 root root 469 Aug 11 2023 rpaf.conf
lrwxrwxrwx 1 root root 27 Aug 11 2023 rpaf.load -> ../mods-available/rpaf.load
lrwxrwxrwx 1 root root 28 Aug 11 2023 ruid2.load -> ../mods-available/ruid2.load
lrwxrwxrwx 1 root root 31 Aug 11 2023 setenvif.conf -> ../mods-available/setenvif.conf
lrwxrwxrwx 1 root root 31 Aug 11 2023 setenvif.load -> ../mods-available/setenvif.load
lrwxrwxrwx 1 root root 36 Aug 11 2023 socache_shmcb.load -> ../mods-available/socache_shmcb.load
lrwxrwxrwx 1 root root 26 Aug 11 2023 ssl.conf -> ../mods-available/ssl.conf
lrwxrwxrwx 1 root root 26 Aug 11 2023 ssl.load -> ../mods-available/ssl.load
lrwxrwxrwx 1 root root 29 Aug 11 2023 suexec.load -> ../mods-available/suexec.load
Then I rebuild all the users:
#!/bin/bash
source /etc/hestiacp/hestia.conf
source $HESTIA/func/main.sh
for user in $($BIN/v-list-users plain | cut -f1 ); do
echo "Doing user: $user"
$BIN/v-rebuild-all $user
done
Which runs through with no errors, apart from:
Error: DNS_SYSTEM is not enabled
Could that be causing the issue?
Cheers
Andy
OMG If ound it!!!
I am on debian 10 with hestia 1.4.17 running. (apache2 + nginx)
I know for sure that webmail.domain.xyz worked a few weeks ago (unfortunately I use webmail rarely so I cannot tell when that changed).
DNS is correct and as said - it surely already worked but yesterday I had to use webmail again and discovered that the webmail only shows the source of the index.php file.
I than tried to switch between rainloop and roundcube (both showed their respective index.php as source)
As I found in …
bash /usr/local/hestia/install/upgrade/manual/migrate_mpm_event.sh
and now it works
sahsanu
February 23, 2024, 2:20pm
17
That script basically do what we already did but it also disables php modules in Apache and that should be the reason it wasn’t working only disabling prefork and enabling event.
system
Closed
March 24, 2024, 2:20pm
18
