VPS21
August 23, 2021, 9:20am
1
The IP of the ovh VPS I got was blacklisted in UCEPROTECT so I went to e-mail spam. OVH said their ASN blacklists had no solution
I bought mailbaby.net service for SMTP Relay for Hestiacp
I added my mail baby for Hestiacp as follows
After adding it, but the recipient will not receive any of the e-mail I send.
After removing the SMTP Relay, the recipient will receive those messages
How do I add mailbaby.net service to Hestiacp so that the recipient receives the e-mail?
mail baby details
Or is there another solution to my problem?
eris
August 23, 2021, 9:22am
2
Did you setup mail relay as an general setting or on domain level?
VPS21
August 23, 2021, 9:34am
3
eris:
general setting
I went to Configure Server> Mail Server> Global SMTP Relay and added, it did not work
Then, I will log in to the User Account and add it to Mail> Edit Mail Domain> SMTP Relay, which also did not work
I have been trying this for a month and tried to reinstall Hestiacp but I could not
Have you checked the exim mainlog to see what exactly fails?
pluto
August 24, 2021, 7:18am
5
Just as a general note, a listing on UCEPROTECT can generally be ignored. It doesn’t seem to affect deliverability, and will generally be removed after a while.
They also seem to require payment for de-listing, which is a curious business model.
eris
August 24, 2021, 7:24am
6
Haven’t checked with Mailbaby yet.
SMTP2GO works fine make sure you set up the correct DNS headers for the sending domains often it is the problem.
Check mainlog what it is not working
pluto
August 24, 2021, 7:29am
7
This is suggested mailbaby config for DirectAdmin
`auth_login:
driver = plaintext
public_name = LOGIN
hide client_send = : mailbaby : 68e9af2444722ffd228497dec28b0ae3b5c6413f7a2a9455c410872770165a66
smart_route:
driver = manualroute
domains = ! +local_domains
ignore_target_hosts = 127.0.0.0/8
condition = "${perl{check_limits}}"
transport = auth_relay
route_list = * relay.mailbaby.net
no_more
auth_relay:
driver = smtp
port = 25
headers_add = "${if def:authenticated_id{X-AuthUser: ${authenticated_id}}}"
interface = <; ${if exists{/etc/virtual/domainips}{${lookup{$sender_address_domain}lsearch*{/etc/virtual/domainips}}}}
helo_data = ${if exists{/etc/virtual/helo_data}{${lookup{$sending_ip_address}iplsearch{/etc/virtual/helo_data}{$value}{$primary_hostname}}}{$primary_hostname}}
hosts_try_chunking =
hosts_try_fastopen =
