Subdomain for Docker Container
Hello everyone
I am currently using Hestia in nginx only mode. Now I have a use case where I want to use a Docker container. I want to make the application accessible via a subdomain.
In another entry here in the forum, it says that you should create a template. However, the template then refers to the proxy mode (proxy_pass). In my opinion, I cannot use this type of template. Correct?
Can I use a php-fpm template at all?
Thanks for your help.
Greetings from Germany
Tobi
Unless you set it up to connect to a socket the only other way is to use proxy pass and a port number …
So do I understand correctly that I have to switch on proxy mode? Is this possible in Nginx only mode?
During the last update I had problems with the domains and in the end I had to delete several lines with proxy at the beginning from hestia.conf. So the proxy mode is off for me.
Perhaps you could briefly explain what I can do?
Yes you can just use a template
And modify the template
I just Created one documentation from you: Connecting PORT/Docker/Python/Node/Other App/Website to Domain | Easily with FREE SSL
Please check it will work surely.
