I added a cron in admin panel to update yt-dlp
sudo /usr/local/bin/yt-dlp -U
But I get this error:
sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
I suggest to use the shell as root user, you cant run other commands outside of $HESTIA/bin with root privileges.
So an easy crontab -e as root user (sudo su in case of deactivated root).
