Sytem Error: nginx restart failed
I get the following error when I try to make changes in the admin panel
But when I try to restart nginx manually, it restarts successfully.
I run systemctl status nginx and everything looks ok.
Any Ideas?
Enable debug mode in the server settings
And make your changes and check /var/log/hestia/debug.log
OK did it… and get the following:
nginx: [emerg] open() "/var/log/nginx/domains/webmail.mydomain.cx.log" failed (24: Too many open files)
nginx: configuration file /etc/nginx/nginx.conf test failed
/etc/systemd/system/nginx.service.d/override.conf does not exist
Create it
Did it but
cat /proc/ < nginx-pid > /limits
-bash: nginx-pid: No such file or directory
And the problem continues
Is there a mabe second nginx config for the hestia panel?
Any Ideas?
Did you literally typed “nginx-pid” or the pid of nginx service running (some number ) ?
ps -ef | grep nginx, look for nginx pid
pgrep nginx
find the program id (pid) of nginx and put the number in place of "nginx-pid’
eg. cat /proc/22343/limits
It seems that there are 2 instances of nginx running
/usr/sbin/nginx -c /etc/nginx/nginx.conf
Limit                     Soft Limit           Hard Limit           Units
Max cpu time              unlimited            unlimited            seconds
Max file size             unlimited            unlimited            bytes
Max data size             unlimited            unlimited            bytes
Max stack size            8388608              unlimited            bytes
Max core file size        0                    unlimited            bytes
Max resident set          unlimited            unlimited            bytes
Max processes             127090               127090               processes
Max open files            1048576              1048576              files
Max locked memory         4170336256           4170336256           bytes
Max address space         unlimited            unlimited            bytes
Max file locks            unlimited            unlimited            locks
Max pending signals       127090               127090               signals
Max msgqueue size         819200               819200               bytes
Max nice priority         0                    0
Max realtime priority     0                    0
Max realtime timeout      unlimited            unlimited            us
/usr/local/hestia/nginx/sbin/hestia-nginx
Max open files            1024                 524288               files
Max locked memory         65536                65536                bytes
The hestia-nginx has the problem I think… where is its config?
hestia-nginx is only used for the panel. It should not be the issue it is the main hestia service…
I understand that, but I get the error only in the panel
systemctl restart Nginx
systemctl status Nginx
We usually reload the config instead of reloading so that might be the issue
I have done that and the status is ok
reboot the server
Did that… again the same :frowning:
Where does the panel create the webmail nginx config per domain?
Here /home/ACCOUNT/conf/mail/DOMAIN/
Hello Again,
The error I get is for all the webmail entries
if I delete one it goes to the next one.
As a note the server is working fine all domains are hosted correctly and nginx starts and restarts succesfuly, only actions within hestia and nginx -t resove with errors.
Also I tried:
sudo -u nginx bash -c 'ulimit -n'
and I get 1024.
Hello Again,
Also I tried:
and I get 1024.
