/tmp didn't clear
So i was doing cleanup and saw I have 9gb worth of session files for months from a 400mb website.
I searched the forum and apparently there is an auto cleanup for tmp folder
# Look for and purge old sessions every 30 minutes
09,39 * * * * root [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi
Question is why do you think it fail?
Not sure if it’s failing now.
That cron job doesn’t fail because it doesn’t executes the session cleanup. As you are using systemd, the one doing the session clean-up is a systemd timer: phpsessionclean.timer that executes the service phpsessionclean.service
systemctl list-timers phpsessionclean
systemctl status phpsessionclean
Also, the php sessions should be by default in dir /var/lib/php/sessions/ not in /tmp/
for i in $(v-list-sys-php plain);do echo "Checking PHP $i";"php${i}" -r 'echo ini_get("session.save_path") . "\n" . ini_get("session.gc_maxlifetime") . "\n";';echo;done
Thank you for the reply.
Here is my output.
Checking PHP 5.6
1440
Checking PHP 7.0
1440
Checking PHP 7.1
1440
Checking PHP 7.2
1440
Checking PHP 7.3
1440
Checking PHP 7.4
1440
Checking PHP 8.0
1440
Checking PHP 8.1
1440
Checking PHP 8.2
1440
Checking PHP 8.3
1440
Sorry I just noticed the cron. It is indeed /usr/lib/php
If that is the case, then what are these in /home/xxx/tmp?
Got the same issue with this one
Other than having to delete them using
# Remove tmp session files over one day old
find /home/user/tmp -type f -name 'sess_*' -mtime +1 -delete
How to prevent this in the first place?
I thought you were talking about /tmp/ instead of /home/USER/tmp/. The default session path is /var/lib/php/sessions/, but Hestia creates custom variables and PHP settings to use /home/USER/tmp/ as upload dir, temporal dir, and session’s path when it creates the pool.
❯ cat /etc/php/8.3/fpm/pool.d/example.net.conf
; origin-src: deb/php-fpm/multiphp.tpl
;# Default Web Domain Template                                             #
;# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS   #
;# https://hestiacp.com/docs/server-administration/web-templates.html      #
[exampple.net]
listen = /run/php/php8.3-fpm-exampple.net.sock
listen.owner = USER
listen.group = www-data
listen.mode = 0660
user = USER
group = USER
pm = ondemand
pm.max_children = 8
pm.max_requests = 4000
pm.process_idle_timeout = 10s
pm.status_path = /status
php_admin_value[upload_tmp_dir] = /home/USER/tmp
php_admin_value[session.save_path] = /home/USER/tmp
php_admin_value[open_basedir] = /home/USER/.composer:/home/USER/web/exampple.net/public_html:/home/USER/web/exampple.net/private:/home/USER/web/exampple.net/public_shtml:/home/USER/tmp:/tmp:/var/www/html:/bin:/usr/bin:/usr/local/bin:/usr/share:/opt
php_admin_value[sendmail_path] = /usr/sbin/sendmail -t -i -f [email protected]
env[PATH] = /usr/local/bin:/usr/bin:/bin
env[TMP] = /home/USER/tmp
env[TMPDIR] = /home/USER/tmp
env[TEMP] = /home/USER/tmp
Hestia also adds a PHP session cleanup cron job that runs daily and removes sessions older than 7 days.
❯ cat /etc/cron.daily/php-session-cleanup
#!/bin/sh
find -O3 /home/*/tmp/ -ignore_readdir_race -depth -mindepth 1 -name 'sess_*' -type f -cmin '+10080' -delete > /dev/null 2>&1
find -O3 /usr/local/hestia/data/sessions/ -ignore_readdir_race -depth -mindepth 1 -name 'sess_*' -type f -cmin '+10080' -delete > /dev/null 2>&1
So, if you have that many GBs in your tmp directory, I suppose it’s because it’s also being used as an upload directory. To have 9 GB of session files, you would need more than 2 million of them.
Upload directory is within the public_html. Never something outside of public_html
As a matter of fact, it was indeed millions of sess files. Even rm -rf * gave me an error that it there were too many to delete.
Website is barely used. So I dont monitor it not until I was doing cleanup.
But I think I see the problem now.
The cleanup searches for sess_*
But the files generated has a name_sess* in it.
I find it unusual because
  1. None of my other websites generating with name_sess*.*
    Just the default sess*
  2. The name is actually the name of the system. Not the website. Not the domain. But the name of the program that I bought from codecanyon.
And after further investigation.
.env of the program has a line
app.sessionCookieName = 'name_session'
After commenting it out, the session files are now named
ci_session*
I guess this is a software specific problem. Not a hestia problem.
Edited the .env to
app.sessionCookieName = 'sess_'
And let’s see what happens
