Upgrades break Backblaze CLI on ARM
When a message similar to this appears in the upgrade script, the Backblaze CLI stops working on ARM servers:
[ * ] Upgrading Backblaze CLI tool to version 3.10.0...
I have had this happen on multiple instances, and have to run the following command to restore functionality:
pip3 install --upgrade --ignore-installed b2
Similar to Backups have stopped working since the last update
No specific resolution was found I think
I suggest using Rclone instead it also supports B2 with out issues…
Rclone is great thank you! Will use instead
Had some trouble with automatic backup this morning…
-- SUMMARY --
2023-12-01 05:10:02 Upload With Rclone to backblaze: admin.2023-12-01_05-10-02.tar
2023/12/01 05:10:18 ERROR : admin.2023-12-01_05-10-02.tar: Failed to copy: no tomes available (503 service_unavailable)
2023/12/01 05:10:18 ERROR : Attempt 1/3 failed with 1 errors and: no tomes available (503 service_unavailable)
2023/12/01 05:10:34 ERROR : admin.2023-12-01_05-10-02.tar: Failed to copy: no tomes available (503 service_unavailable)
2023/12/01 05:10:34 ERROR : Attempt 2/3 failed with 1 errors and: no tomes available (503 service_unavailable)
2023/12/01 05:10:49 ERROR : admin.2023-12-01_05-10-02.tar: Failed to copy: no tomes available (503 service_unavailable)
2023/12/01 05:10:49 ERROR : Attempt 3/3 failed with 1 errors and: no tomes available (503 service_unavailable)
2023/12/01 05:10:49 INFO  :
Transferred:        5.289 MiB / 5.289 MiB, 100%, 118.351 KiB/s, ETA 0s
Errors:                 1 (retrying may help)
Elapsed time:        47.1s
2023/12/01 05:10:49 Failed to copy: no tomes available (503 service_unavailable)
Error: Unable to upload backup
I suppose the B2 CLI automatically took care of stuff like this
It looks like there was an issue with B2 last night…
Try again now?
You sure they had issues last night? Link is from August
Hmm works fine with manual backup a minute ago…
-- SUMMARY --
2023-12-01 11:20:02 Upload With Rclone to backblaze: admin.2023-12-01_11-20-02.tar
2023/12/01 11:20:06 INFO  : admin.2023-12-01_11-20-02.tar: Copied (new)
Transferred:        2.168 MiB / 2.168 MiB, 100%, 430.018 KiB/s, ETA 0s
Transferred:            1 / 1, 100%
Elapsed time:         3.6s
Delete file: admin.2023-11-30_20-40-02.tar
2023-12-01 11:20:09 Rotated: 2023-11-30_20-40-02
2023-12-01 11:20:09 Rotated: 2023-12-01_05-10-02
2023-12-01 11:20:09 Local: /backup/admin.2023-12-01_11-20-02.tar
2023-12-01 11:20:09 Size: 3 MB
2023-12-01 11:20:09 Runtime: 1 minute
Perhaps the issue comes from trying to upload multiple backups from multiple servers to B2 on the same time of day?
Service 503 look like it was just an issue with B2
It works now just wait till tonight and check again…
Backups have been working flawlessly since
Thank you
