Using port 80 or 443 for control panel instead 8083
What is the main reason to use the port 8083 to login to control panel?
In a server I don’t have full access it’s blocked and that is a pain. I don’t see the reason no to use 80 or 443 so that we don’t need to specify port at all on the browser. Is there an easy way to just use a subdomain to login for example? I think that would be the most logical by default unless there is a strong reason not to do this.
You can use other ports.
You may be able to create a custom template for a different approach. I don’t have any example to guide you toward.
It runs under a separate services…
Ha ok. Thanks…
You could create a template for nginx that parses the web ui:
/usr/local/hestia/data/templates/web/nginx/hestia_cp.stpl
# Default Web Domain Template                                           #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
server {
    listen      %ip%:%proxy_ssl_port% ssl http2;
    ssl_certificate      %ssl_pem%;
    ssl_certificate_key  %ssl_key%;
    ssl_stapling on;
    ssl_stapling_verify on;
    error_log  /var/log/%web_system%/domains/%domain%.error.log error;
    location / {
        proxy_pass      https://%ip%:8083;
    location /error/ {
        alias   %home%/%user%/web/%domain%/document_errors/;
    location @fallback {
        proxy_pass      https://%ip%:%web_ssl_port%;
       deny all;
       return 404;
    include     /etc/nginx/conf.d/phpmyadmin.inc*;
    include     /etc/nginx/conf.d/phppgadmin.inc*;
/usr/local/hestia/data/templates/web/nginx/hestia_cp.tpl
server {
    location / {
    return 301 https://%domain_idn%/;
    location /error/ {
       deny all;
       return 404;
if you are having trouble with the port, replace in the template: %ip% with localhost
Hello.
Is it also functional through Nginx - PHP FPM or only Nginx (Proxy)? Thank you.
This templates should cover both, but you have to select the Proxy Template: hestia_cp if done as instructed
