V-add-letsencrypt-domain cron job error
I am getting at Hestia error.log this error running every 5 min for the last 13 days non stopping. It’s about a cron job for a sub domain I created then deleted at the same day. I have removed the DNS records of the sub domain and tried to remove then rerun Let’s Encrypt from HestiaCP but that didn’t stop the error.
2020-09-17 11:45:01 v-list-dns-records ‘USER’ ‘SUB.WORDPRESS.(1)’ [Error 3]
2020-09-17 11:45:01 v-add-letsencrypt-domain ‘USER’ ‘SUB.WORDPRESS.(1)’ ‘’ ‘no’ ‘yes’ [Error 3]
Can you help stop this error.
Regards,
Nasser
Check if you can see something in /usr/local/hestia/data/queue/letsencrypt.pipe and remove the contents
Thank you eris for your support.
This is the content of letsencrypt.pipe. I am not sure what to remove?
It should be normally empty unless there is a task to …
The file you posted is the content of https://github.com/hestiacp/hestiacp/blob/main/bin/v-update-letsencrypt-ssl
Thanks eris, the error stopped.
