Webmail domain -> Static "Success!" page
Hello Forum,
I’ve run into a problem on my Hestia server, which I hope you can shred some light on.
After installing Hestia, everything was working fine, but I noticed I didn’t have an SSL certificate for my “webmail” subdomain, used when checking Roundcube.
So I figured the sensible thing to do, would be to create a subdomain on my account, and use the “webmail” as the name, to get an SSL cert via certbot.
However, looking back, this probably wasn’t a smart idea, as when I went to visit the webmail.domain.com, I was redirected to the static “Coming Soon” page, used when you create new subdomains.
I panicked, and quickly deleted the subdomain “webmail”, but now it’s stuck on “Success! Your new web server is ready to use.” page.
This means I cannot use Roundcube for any email accounts, as they all redirect me through webmail.domain.com…
The forwarding rules I set up still work, but I really need access to the roundcube interface for sending emails.
Hopefully someone in here can help me sort this, and if I could get a little help on getting an SSL cert for the real webmail domain, it would be appreciated as well.
Thank you in advance!
v-add-sys-webmail user domain probally
Thanks, can you clarify a bit further please?
user being the username of an account?
I assumed the webmail.doma.in would automatically be set to the domain the email account is registered to?
And the same goes for the domain in your command.
I really appreciate you trying to help though.
Just might need to go into a bit further details for me to fully understand.
Once again, thank you in advance.
https://docs.hestiacp.com/cli_commands/commands.html#v-add-sys-webmail
Or check here Without access to RoundCube on webmail.domain.tld
This looks like exactly what I’m looking for.
Sorry for not finding it, I actually did search for previous topics, but was unable to find anything.
Thanks guys!
With the release of 1.4.0 it will be come more accessable via the Web GUI
Sorry to bring back attention, but unfortunately I’ve run into another issue with the posted solution.
Whenever I run v-delete-sys-webmail in terminal, I get “command not found”.
Same goes for v-delete-sys-webmail.
Running the command as root or with sudo made no difference.
Any idea what I’m doing wrong?
use the full path
Or add
if [ "${PATH#*/usr/local/hestia/bin*}" = "$PATH" ]; then
    . /etc/profile.d/hestia.sh
fi
to ~/.bashrc and then reload the session
