Record ptr reverse dns
i have this problem with reverse dns on OCI
i must change the ptr to omargaiani.com …or i can solve in another way
without open a ticket with OCI
v-change-sys-hostname newhostname.com to update the hostname it is used for the help name look up if I am right.
i m sorry but i must run : v-change-sys-hostname newhostname.com
or i change it in the exim4.conf.4.94.template
becouse the host name in the instance is correct configurated
v-change-dus-hostname should be enough
when i instal hestia i have done the hostname like in this message of the forum
cheers
Omar
You will need to involve OCI to alter the PTR record. The required steps are outlined in the following article.
i have already done it with OCI before configure hestia
my PTR record work with hcp.omargaiani.com
i have this from mxtoobox :
and i don’t know haw is the :
sgm-ubuntu.subnet09121748.vcn09121748.oraclevcn.com Hello keeper-us-east-1d.mxtoolbox.com
may be instance name
how you set up reverse DNS in OCI instance???
facing same issue!!!, please help
Contact Oracle Support …
Completed process of PTR record.
But still showing this error as below.
Hostname and PTR record need to match so update the hostname
hostname is 1.cloud.yesbhautikx.co.in only
below is my /etc/exim4/exim4.conf.template
#          Exim configuration file for Hestia Control Panel          #
#SPAMASSASSIN = yes
#SPAM_SCORE = 50
#SPAM_REJECT_SCORE = 100
#CLAMD = yes
smtp_banner = $smtp_active_hostname
smtp_active_hostname = ${lookup dnsdb{>: defer_never,ptr=$interface_address}{${listextract{1}{$value}}}{$primary_hostname}}
add_environment = <; PATH=/bin:/usr/bin
keep_environment =
disable_ipv6 = true
smtputf8_advertise_hosts =
domainlist local_domains = dsearch;/etc/exim4/domains/
domainlist relay_to_domains = dsearch;/etc/exim4/domains/
hostlist relay_from_hosts = 127.0.0.1
hostlist whitelist = net-iplsearch;/etc/exim4/white-blocks.conf
hostlist spammers = net-iplsearch;/etc/exim4/spam-blocks.conf
no_local_from_check
untrusted_set_sender = *
acl_smtp_connect = acl_check_spammers
acl_smtp_mail = acl_check_mail
acl_smtp_rcpt = acl_check_rcpt
acl_smtp_data = acl_check_data
acl_smtp_mime = acl_check_mime
.ifdef SPAMASSASSIN
spamd_address = 127.0.0.1 783
.endif
.ifdef CLAMD
av_scanner = clamd: /run/clamav/clamd.ctl
.endif
log_selector = +tls_sni
tls_advertise_hosts = *
# We test that $tls_in_sni is a valid domain, by an arbitrary email address [email protected] .
# Then, we extract the domain with a function that would fail if the email address is invalid.
# If the certificate exists, we will use it, otherwise the default certificate in /etc/ssl will be used.
tls_certificate = \
        ${if and {\
                     { eq {${domain:foo@$tls_in_sni}} {$tls_in_sni}}\
                     { exists{/usr/local/hestia/ssl/mail/$tls_in_sni.crt} }\
                 {/usr/local/hestia/ssl/mail/$tls_in_sni.crt}\
                 {/usr/local/hestia/ssl/certificate.crt}\
tls_privatekey = \
        ${if and {\
                     { exists{/usr/local/hestia/ssl/mail/$tls_in_sni.key} }\
                 {/usr/local/hestia/ssl/mail/$tls_in_sni.key}\
                 {/usr/local/hestia/ssl/certificate.key}\
daemon_smtp_ports = 25 : 465 : 587
tls_on_connect_ports = 465
tls_require_ciphers = PERFORMANCE:-RSA:-VERS-ALL:+VERS-TLS1.2:+VERS-TLS1.3:%SERVER_PRECEDENCE
never_users = root
host_lookup = *
rfc1413_hosts = *
rfc1413_query_timeout = 0s
ignore_bounce_errors_after = 2d
timeout_frozen_after = 7d
DKIM_DOMAIN = ${lc:${domain:$h_from:}}
DKIM_FILE = /etc/exim4/domains/${lookup{${lc:${domain:$h_from:}}}dsearch{/etc/exim4/domains/}}/dkim.pem
DKIM_PRIVATE_KEY = ${if exists{DKIM_FILE}{DKIM_FILE}{0}}
OUTGOING_IP = /etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/ip
SMTP_RELAY_FILE = ${if exists{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/smtp_relay.conf}}
SMTP_RELAY_HOST = ${lookup{host}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PORT = ${lookup{port}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_USER = ${lookup{user}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PASS = ${lookup{pass}lsearch{SMTP_RELAY_FILE}}
# Custom Filter
system_filter = /etc/exim4/system.filter
system_filter_user = Debian-exim
#                       ACL CONFIGURATION                            #
#         Specifies access control lists for incoming SMTP mail      #
acl_not_smtp = acl_not_smtp
begin acl
acl_not_smtp:
  deny    message       = Website of user $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
  ratelimit             = 200 / 1h / $authenticated_id
  warn    ratelimit     = 100 / 1h / strict / $authenticated_id
  log_message           = Sender rate [limitlog]: log / account / $authenticated_id / $sender_rate / $sender_rate_period
  accept
acl_check_spammers:
  accept  hosts         = +whitelist
  drop    message       = Your host in blacklist on this server.
          log_message   = Host in blacklist
          hosts         = +spammers
  accept
acl_check_mail:
  deny    condition     = ${if eq{$sender_helo_name}{}}
          message       = HELO required before MAIL
  drop    !authenticated = *
    	  message       =  Helo name contains an IP address (HELO was $sender_helo_name) and not is valid
          condition     = ${if match{$sender_helo_name}{\N((\d{1,3}[.-]\d{1,3}[.-]\d{1,3}[.-]\d{1,3})|([0-9a-f]{8})|([0-9A-F]{8}))\N}{yes}{no}}
          condition     = ${if match {${lookup dnsdb{>: defer_never,ptr=$sender_host_address}}\}{$sender_helo_name}{no}{yes}}
          delay         = 45s
		  condition     = ${if isip{$sender_helo_name}}
          message       = Access denied - Invalid HELO name (See RFC2821 4.1.3)
		  condition    = ${if eq{[$interface_address]}{$sender_helo_name}}
          message       = $interface_address is _my_ address
  accept
acl_check_rcpt:
  accept  hosts         = :
# Limit per email account for SMTP auhenticated users
  deny    message       = Email account $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
          set acl_c_msg_limit  = ${if exists{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{${lookup {$authenticated_id} lsearch{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{$value}{${readfile{/etc/exim4/limit.conf}}}}}{${readfile{/etc/exim4/limit.conf}}} }
          ratelimit     = $acl_c_msg_limit / 1h / strict/ $authenticated_id
  warn    ratelimit     = ${eval:$acl_c_msg_limit / 2} / 1h / strict / $authenticated_id
  log_message           = Sender rate [limitlog]: log / email / $authenticated_id / $sender_rate / $sender_rate_period
  deny    message       = Restricted characters in address
          domains       = +local_domains
          local_parts   = ^[.] : ^.*[@%!/|]
          domains       = !+local_domains
          local_parts   = ^[./|] : ^.*[@%!] : ^.*/\\.\\./
  require verify        = sender
  accept  hosts         = +relay_from_hosts
          control       = submission
  accept  authenticated = *
          control       = submission/domain=
  deny    message       = Rejected because $sender_host_address is in a black list at $dnslist_domain\n$dnslist_text
          hosts         = !+whitelist
          dnslists      = ${readfile {/etc/exim4/dnsbl.conf}{:}}
  require message       = relay not permitted
          domains       = +local_domains : +relay_to_domains
  deny    message       = smtp auth required
         sender_domains = +local_domains
         !authenticated = *
  require verify        = recipient
.ifdef CLAMD
  warn    set acl_m0    = no
  warn    condition     = ${if exists {/etc/exim4/domains/$domain/antivirus}{yes}{no}}
          set acl_m0    = yes
.endif
.ifdef SPAMASSASSIN
 warn    set acl_m1    = no
         set acl_m3    = no
 warn    condition     = ${if exists {/etc/exim4/domains/$domain/antispam}{yes}{no}}
         set acl_m1    = yes
 warn    condition     = ${if exists {/etc/exim4/domains/$domain/reject_spam}{yes}{no}}
         set acl_m3    = yes
.endif
  accept
acl_check_data:
.ifdef CLAMD
  deny   message        = Message contains a virus ($malware_name) and has been rejected
         malware        = */defer_ok
         condition      = ${if eq{$acl_m0}{yes}{yes}{no}}
.endif
.ifdef SPAMASSASSIN
 warn   !authenticated = *
        hosts          = !+relay_from_hosts
        condition      = ${if < {$message_size}{1024K}}
        condition      = ${if eq{$acl_m1}{yes}{yes}{no}}
        spam           = debian-spamd:true/defer_ok
        add_header     = X-Spam-Score: $spam_score_int
        add_header     = X-Spam-Bar: $spam_bar
        add_header     = X-Spam-Report: $spam_report
        set acl_m2     = $spam_score_int
 warn   condition      = ${if !eq{$acl_m2}{} {yes}{no}}
        condition      = ${if >{$acl_m2}{SPAM_SCORE} {yes}{no}}
        add_header     = X-Spam-Status: Yes
        message        = SpamAssassin detected spam (from $sender_address to $recipients).
  # Deny spam at high score if spam score > SPAM_REJECT_SCORE and delete_spam is enabled
  deny   message        = This message scored $spam_score spam points
         condition      = ${if eq{$acl_m3}{yes}{yes}{no}}
         condition      = ${if >{$spam_score_int}{SPAM_REJECT_SCORE}{1}{0}}
.endif
  accept
acl_check_mime:
  deny   message        = Blacklisted file extension detected
         condition      = ${if match {${lc:$mime_filename}}{\N(\.ace|\.ade|\.adp|\.app|\.arj|\.asp|\.aspx|\.asx|\.bas|\.bat|\.cab|\.cer|\.chm|\.cmd|\.cnt|\.com|\.cpl|\.crt|\.csh|\.der|\.diagcab|\.dll|\.efi|\.exe|\.fla|\.fon|\.fxp|\.gadget|\.grp|\.hlp|\.hpj|\.hta|\.htc|\.img|\.inf|\.ins|\.iso|\.isp|\.its|\.jar|\.jnlp|\.js|\.jse|\.ksh|\.lib|\.lnk|\.mad|\.maf|\.mag|\.mam|\.maq|\.mar|\.mas|\.mat|\.mau|\.mav|\.maw|\.mcf|\.mda|\.mdb|\.mde|\.mdt|\.mdw|\.mdz|\.msc|\.msh|\.msh1|\.msh1xml|\.msh2|\.msh2xml|\.mshxml|\.msi|\.msp|\.mst|\.msu|\.ops|\.osd|\.pcd|\.pif|\.pl|\.plg|\.prf|\.prg|\.printerexport|\.ps1|\.ps1xml|\.ps2|\.ps2xml|\.psc1|\.psc2|\.psd1|\.psdm1|\.pst|\.py|\.pyc|\.pyo|\.pyw|\.pyz|\.pyzw|\.reg|\.scf|\.scr|\.sct|\.sfx|\.shb|\.shs|\.swf|\.sys|\.theme|\.tmp|\.ttf|\.url|\.vb|\.vba|\.vbe|\.vbp|\.vbs|\.vhd|\.vhdx|\.vsmacros|\.vsw|\.vxd|\.webpnp|\.website|\.wim|\.ws|\.wsc|\.wsf|\.wsh|\.xbap|\.xll|\.xnk)$\N}{1}{0}}
  accept
#                   AUTHENTICATION CONFIGURATION                     #
begin authenticators
smtp_relay_login:
  driver = plaintext
  public_name = LOGIN
  hide client_send = : SMTP_RELAY_USER : SMTP_RELAY_PASS
dovecot_plain:
  driver = dovecot
  public_name = PLAIN
  server_socket = /run/dovecot/auth-client
  server_set_id = $auth1
dovecot_login:
  driver = dovecot
  public_name = LOGIN
#                      ROUTERS CONFIGURATION                         #
#               Specifies how addresses are handled                  #
begin routers
send_via_unauthenticated_smtp_relay:
  driver = manualroute
  address_data = SMTP_RELAY_HOST:SMTP_RELAY_PORT
  require_files = SMTP_RELAY_FILE
  condition = ${if eq{SMTP_RELAY_USER}{}}
  transport = remote_smtp
  route_list = * ${extract{1}{:}{$address_data}}::${extract{2}{:}{$address_data}}
  no_more
  no_verify
send_via_smtp_relay:
  transport = smtp_relay_smtp
  no_more
  no_verify
dnslookup:
  driver = dnslookup
  no_more
userforward:
  driver = redirect
  check_local_user
  file = $home/.forward
  require_files = ${local_part}:+${home}/.forward
  allow_filter
  no_verify
  no_expn
  check_ancestor
  file_transport = address_file
  pipe_transport = address_pipe
  reply_transport = address_reply
procmail:
  driver = accept
  check_local_user
  require_files = ${local_part}:+${home}/.procmailrc:/usr/bin/procmail
  transport = procmail
  no_verify
autoreplay:
  driver = accept
  require_files = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg
  condition = ${if exists{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg}{yes}{no}}
  retry_use_local_part
  transport = userautoreply
  unseen
aliases:
  driver = redirect
  headers_add = X-redirected: yes
  data = ${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
  require_files = /etc/exim4/domains/$domain/aliases
  redirect_router = dnslookup
  unseen
localuser_fwd_only:
  driver = accept
  transport = devnull
  condition = ${if exists{/etc/exim4/domains/$domain/fwd_only}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/fwd_only}{true}{false}}}}
localuser_spam:
  driver = accept
  transport = local_spam_delivery
  condition = ${if eq {${if match{$h_X-Spam-Status:}{\N^Yes\N}{yes}{no}}} {${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{yes}{no_such_user}}}}
localuser:
  driver = accept
  transport = local_delivery
  local_part_suffix = +* : .*
  local_part_suffix_optional
  condition = ${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{true}{false}}
catchall:
  driver = redirect
  data = ${extract{1}{:}{${lookup{*@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
  file_transport = local_delivery
  condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{false}{true}}
terminate_alias:
  driver = accept
  transport = devnull
  condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{true}{false}}
#                      TRANSPORTS CONFIGURATION                      #
begin transports
smtp_relay_smtp:
  driver = smtp
remote_smtp:
  driver = smtp
  helo_data = ${lookup dnsdb{>: defer_never,ptr=$sending_ip_address}{${listextract{1}{$value}}}{$primary_hostname}}
  dkim_domain = DKIM_DOMAIN
  dkim_selector = mail
  dkim_private_key = DKIM_PRIVATE_KEY
  dkim_canon = relaxed
  dkim_strict = 0
  hosts_try_fastopen = !*.l.google.com
  interface = ${if exists{OUTGOING_IP}{${readfile{OUTGOING_IP}}}}
procmail:
  driver = pipe
  command = "/usr/bin/procmail -d $local_part"
  return_path_add
  delivery_date_add
  envelope_to_add
  user = $local_part
  initgroups
  return_output
local_delivery:
  driver = appendfile
  maildir_format
  maildir_use_size_file
  user = ${extract{2}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}
  group = mail
  create_directory
  directory_mode = 770
  mode = 660
  use_lockfile = no
  delivery_date_add
  envelope_to_add
  return_path_add
  directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
  quota = ${extract{6}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}M
  quota_warn_threshold = 75%
local_spam_delivery:
  driver = appendfile
  maildir_format
  group = mail
  create_directory
  mode = 660
  use_lockfile = no
  delivery_date_add
  envelope_to_add
  return_path_add
  directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}/.Spam"
  quota_directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
address_pipe:
  driver = pipe
  return_output
address_file:
  driver = appendfile
  delivery_date_add
  envelope_to_add
  return_path_add
address_reply:
  driver = autoreply
userautoreply:
  driver = autoreply
  file = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}.msg
  from = "${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}@${lookup{$domain}dsearch{/etc/exim4/domains/}}"
  headers = Content-Type: text/plain; charset=utf-8;\nContent-Transfer-Encoding: 8bit
  subject = "${if def:h_Subject: {Autoreply: \"${rfc2047:$h_Subject:}\"} {Autoreply Message}}"
  to = "${sender_address}"
devnull:
  driver = appendfile
  file = /dev/null
#                      RETRY CONFIGURATION                           #
begin retry
# Address or Domain    Error       Retries
*                      *           F,2h,15m; G,16h,1h,1.5; F,4d,6h
#                      REWRITE CONFIGURATION                         #
begin rewrite
and this is my /etc/hosts
127.0.0.1       localhost
# The following lines are desirable for IPv6 capable hosts
::1     ip6-localhost   ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
127.0.1.1       yesbhautik-cloud-hestia-01      yesbhautik-cloud-hestia-01
127.0.0.1 1.cloud.yesbhautikx.co.in
Anyone please give solution!
You could change it manually into exim conf but exim should get it automatically…t I suppose you have several ips and exim is taking the one that doesn’t have the right ptr.
Please, show the output of these commands:
for i in $(ip a | awk '/inet / {print $2}' | cut -d '/' -f1); do dig -x $i | grep -vE '^;|^$';done
hostname
hostname -f
hostnamectl hostname
cat /etc/hostname
So, seems 10.0.0.223 is your primary ip and that is the reason exim is getting another ptr.
I don’t want to mess your net conf so I suppose the “easy” way is to modify exim4 to use the right hostname.
First backup exim4 conf just in case…
Check what are the directives using lookup dnsdb to get the primary_hostname:
grep '${lookup dnsdb{>: defer_never,ptr=$.*}{${listextract{1}{$value}}}{$primary_hostname}}' /etc/exim4/exim4.conf.template
You should see 3 of them, one smtp_active_hostname and two helo_data. Search them in exim conf file and just replace their values with your hostname.
smtp_active_hostname = 1.cloud.yesbhautikx.co.in
helo_data = 1.cloud.yesbhautikx.co.in
Save the conf file and restart exim4.
root@1:~# systemctl status exim4
× exim4.service - LSB: exim Mail Transport Agent
     Loaded: loaded (/etc/init.d/exim4; generated)
     Active: failed (Result: exit-code) since Fri 2023-10-27 19:05:27 IST; 3min 14s ago
    Process: 2854 ExecStart=/etc/init.d/exim4 start (code=exited, status=1/FAILURE)
        CPU: 193ms
Oct 27 19:05:26 1.cloud.yesbhautikx.co.in systemd[1]: Starting LSB: exim Mail Transport Agent...
Oct 27 19:05:26 1.cloud.yesbhautikx.co.in exim4[2854]:  * Starting MTA
Oct 27 19:05:27 1.cloud.yesbhautikx.co.in exim4[3226]: 2023-10-27 19:05:27 Exim configuration error in line 361 of /var/lib/exim4/conf>Oct 27 19:05:27 1.cloud.yesbhautikx.co.in exim4[3226]:   "helo_data" option set for the second time
Oct 27 19:05:27 1.cloud.yesbhautikx.co.in exim4[3539]: Invalid new configfile /var/lib/exim4/config.autogenerated.tmp, not installing
Oct 27 19:05:27 1.cloud.yesbhautikx.co.in exim4[3539]: /var/lib/exim4/config.autogenerated.tmp to /var/lib/exim4/config.autogenerated
Oct 27 19:05:27 1.cloud.yesbhautikx.co.in systemd[1]: exim4.service: Control process exited, code=exited, status=1/FAILURE
Oct 27 19:05:27 1.cloud.yesbhautikx.co.in systemd[1]: exim4.service: Failed with result 'exit-code'.
Oct 27 19:05:27 1.cloud.yesbhautikx.co.in systemd[1]: Failed to start LSB: exim Mail Transport Agent.
Below is my new conf. file
#SPAMASSASSIN = yes
#SPAM_SCORE = 50
#CLAMD = yes
keep_environment =
disable_ipv6 = true
no_local_from_check
.ifdef SPAMASSASSIN
.endif
.ifdef CLAMD
.endif
tls_certificate = \
        ${if and {\
tls_privatekey = \
        ${if and {\
never_users = root
host_lookup = *
rfc1413_hosts = *
# Custom Filter
begin acl
acl_not_smtp:
  accept
acl_check_spammers:
          hosts         = +spammers
  accept
acl_check_mail:
          delay         = 45s
  accept
acl_check_rcpt:
  accept  hosts         = :
          hosts         = !+whitelist
         !authenticated = *
.ifdef CLAMD
          set acl_m0    = yes
.endif
.ifdef SPAMASSASSIN
         set acl_m3    = no
         set acl_m1    = yes
         set acl_m3    = yes
.endif
  accept
acl_check_data:
.ifdef CLAMD
.endif
.ifdef SPAMASSASSIN
.endif
  accept
acl_check_mime:
  accept
smtp_relay_login:
  driver = plaintext
  public_name = LOGIN
dovecot_plain:
  driver = dovecot
  public_name = PLAIN
dovecot_login:
  driver = dovecot
  public_name = LOGIN
begin routers
  no_more
  no_verify
  no_more
  no_verify
dnslookup:
  driver = dnslookup
  no_more
userforward:
  driver = redirect
  check_local_user
  allow_filter
  no_verify
  no_expn
  check_ancestor
procmail:
  driver = accept
  check_local_user
  no_verify
autoreplay:
  driver = accept
  unseen
aliases:
  driver = redirect
  unseen
localuser_fwd_only:
  driver = accept
  transport = devnull
localuser_spam:
  driver = accept
localuser:
  driver = accept
catchall:
  driver = redirect
terminate_alias:
  driver = accept
  transport = devnull
begin transports
smtp_relay_smtp:
  driver = smtp
remote_smtp:
  driver = smtp
  dkim_strict = 0
procmail:
  driver = pipe
  return_path_add
  delivery_date_add
  envelope_to_add
  user = $local_part
  initgroups
  return_output
local_delivery:
  driver = appendfile
  maildir_format
  group = mail
  create_directory
  mode = 660
  use_lockfile = no
  delivery_date_add
  envelope_to_add
  return_path_add
  driver = appendfile
  maildir_format
  group = mail
  create_directory
  mode = 660
  use_lockfile = no
  delivery_date_add
  envelope_to_add
  return_path_add
address_pipe:
  driver = pipe
  return_output
address_file:
  driver = appendfile
  delivery_date_add
  envelope_to_add
  return_path_add
address_reply:
  driver = autoreply
userautoreply:
  driver = autoreply
devnull:
  driver = appendfile
  file = /dev/null
begin retry
begin rewrite
Please, make easier for others to help you. That’s basic common sense… how to copy text in shell - Google Suche
updated!
